Invantive UniversalSQL allows for driver-specific PSQL packages as well as generic packages. The generic packages are always available, independent of what data containers are currently connected.
The documentation is primarily available as Data Dictionary views, with names starting with SystemPackage
Generic package cloud_http
: Cloud HTTP utilities
The cloud_http package provides functions to handle HTTP pages. The following procedures and functions are available.
cloud_http.append_line_to_response_body_text
: Append text line to body
Append the text supplied as parameter to the HTML body output, followed by a linefeed.
Parameters:
- txt: string, not null
cloud_http.append_to_response_body_text
: Append text line
Append the text supplied as parameter to the HTML body output.
Parameters:
cloud_http.get_pool_identity
: Get pool identity
Gets the pool identity.
cloud_http.get_request_form_value
: Get value of request form element
Gets the first form value of the key specified as text value parameter.
Parameters:
- key: string, not null
cloud_http.get_request_header_value
: Get value of request header
Gets the first header value of the key specified as text value parameter.
Parameters:
cloud_http.get_request_query_parameter_value
: Get value of query parameter
Gets the first query string value of the key specified as text value parameter.
Parameters:
cloud_http.get_request_relative_path
: Get relative path of request
Gets the path from the URL relative to the module specification.
cloud_http.get_request_relative_path_to_module
: Get relative path to module of request
Gets an URL path for the current page to the root URL of the module.
cloud_http.get_request_url
: Get request URL
Gets the full URL of the request.
cloud_http.set_response_body_binary
: Set response body to binary value
Set the HTML body output to the BLOB supplied as parameter.
Parameters:
- bin: byte[], not null
cloud_http.set_response_body_text
: Set response body to text value
Set/replace the HTML body output by the text supplied as parameter.
Parameters:
cloud_http.set_response_content_type
: Set Content-Type
Sets the Content-Type header to the text value specified.
Parameters:
- contentType: string, not null
cloud_http.set_response_header_value
: Set response header value
Sets the first header value of the response to the value provided.
Parameters:
- value: string, not null
cloud_http.set_response_status_code
: Set response status code
Sets the HTTP response status code.
Parameters:
- statusCode: int16, not null
cloud_http.set_template_step_name
: Set template step name
Sets the step name to the text value supplied as parameter. Only used with Invantive Cloud HTML templates. The step is shown in Invantive Cloud after the module name in the blue title bar.
Parameters:
- name: string, not null
cloud_http.set_use_template
: Whether to use templates
Sets whether to embed the output in the Invantive Cloud HTML template based upon the boolean supplied as parameter. Defaults to false.
Parameters:
- use: boolean, not null
Generic package cloud_metadata
: Cloud HTTP metadata utilities
The cloud_metadata package provides access to metadata of Invantive Cloud applications. The following procedures and functions are available.
cloud_metadata.execute_module
: Run module
Runs a module, specified by application code, module code and parameter values. Output is ignore.
Parameters:
- application_code: string, not null
- module_code: string, not null
- parameter_1: string, not null
- parameter_10: string, not null
- parameter_2: string, not null
- parameter_3: string, not null
- parameter_4: string, not null
- parameter_5: string, not null
- parameter_6: string, not null
- parameter_7: string, not null
- parameter_8: string, not null
- parameter_9: string, not null
cloud_metadata.execute_module_returning_binary
: Retrieve binary output of a module
Runs another module, specified by application code, module code and parameter values. Returns the output as binary.
Parameters:
cloud_metadata.execute_module_returning_text
: Retrieve text output of a module
Runs another module, specified by application code, module code and parameter values. Returns the output as text.
Parameters:
Generic package dbms_lock
: Locking utilities
The dbms_lock package provides functions to assist in resource locking and timing. The following procedures and functions are available.
dbms_lock.sleep
: Sleep some time
Postpone execution for the number of seconds indicated. The method accepts a single parameter indicating the number of seconds as a decimal with sub-second resolution.
Parameters:
- seconds: decimal, not null
Generic package dbms_output
: Print output utilities
The dbms_output package provides functions to send text to an output channel. The following procedures and functions are available.
dbms_output.put
: Print text
Output the text supplied as parameter. An optional second parameter is the text label of the channel.
Parameters:
- channel: string, not null
dbms_output.put_line
: Print line of text
Output the text supplied as parameter and add a linefeed. An optional second parameter is the text label of the channel.
Parameters:
Generic package dbms_audit
: Audit utilities
The dbms_audit package provides functions to increase serviceability by auditing events. The following procedures and functions are available.
dbms_audit.register_event
: Register an audit event.
Output the text supplied as parameter as a system message.
Parameters:
- message_code: Code of the message.
- txt: string, not null, Text of audit event.
- natural_key: string, Natural key.
- reference_key: string, Key of referenced record.
- reference_table_code: string, Table code of referenced record.
- gui_action: string, GUI action.
- gui_module: string, GUI module name and version (obsoleted).
- gui_module_name: string, GUI module name.
- gui_module_version: string, GUI module version.
- partition: string, Partition code.
- provider_name: string, Name of the provider.
- session_id: string, Session ID.
- data_container_id: string, Data container ID.
- message_uid, guid, Non-unique message ID.
- sql_statement: string, SQL statement.
- application_name: string, Application name and version.
- application_user: string, Application user.
Generic package dbms_trace
: Trace logging utilities
The dbms_trace package provides functions to increase serviceability by logging events. The following procedures and functions are available.
dbms_trace.put_line
: Print line of logging
Output the text supplied as parameter to trace logging.
Parameters:
dbms_trace.register_exception
: Register exception
Register the current exception on Invantive Cloud, even when suppressed by an exception block. Only valid within an exception block.
Generic package excel
: Excel package
The Excel package enables generation of Excel workbooks. The following procedures and functions are available.
excel.add_worksheet
: Add worksheet
Add a worksheet to an Excel workbook.
Parameters:
- name: string, not null. Valid name for Excel worksheet.
- workbook: object, not null. Reference to Excel workbook.
excel.autofit_worksheet
: Adapt worksheet columns’ width
Adapt worksheet columns’ width to contents.
Parameters:
- worksheet: object, not null
excel.close
: Close the workbook
Close the workbook.
Parameters:
excel.export_to_xlsx
: Export to XLSX
Export the current contents of an Excel workbook as an XLSX-file.
Parameters:
excel.fill_using_query
: Store query results in workbook
Store the output of a query in an Excel workbook.
Parameters:
- addHeader: boolean, null, default True. Whether to add a header row.
- dataRangeName: string, null. Name of named range to create for the contents.
- query: string, not null. Invantive UniversalSQL query which returns intended contents.
- startPosition: string, null, default A1. Intended top-left start position in Excel single cell notation.
- worksheet: object, not null. Reference to Excel workbook.
excel.new
: Create new workbook
Create an empty Excel workbook which can be filled using the excel package.
excel.set_cell_contents
: Set the contents of a cell
Set the contents of a cell.
Parameters:
- cell: string, not null
- value: object, not null
excel.set_worksheet_name
: Set worksheet name
Set the worksheet’s name.
Parameters:
