The Invantive SQL-driver for Odoo has been extended to cover all SQL DML-operations:
insert
update
delete
synchronize
All Invantive SQL DML-operations are automatically and transparently mapped to external API calls for Odoo on the selected Odoo database.
For example, the following statement updates the name of all Odoo accounts with a code starting with 70000 to the original name plus " (OLD, DO NOT USE)":
update account.account
set name = name || ' (OLD, DO NOT USE)'
where code like '70000%'
Thanks to metadata driven approach of Odoo and the recent performance improvements for very large Odoo environments of Invantive SQL, the execution of such statements performs well even in large databases.
The availability of DML-operations on Odoo enables use of Invantive SQL to cost effectively build reliable data exchange and data integration solutions between Odoo and the other approximately 80 (cloud)platforms and external formats covered by Invantive SQL.
Samples on data integration concepts using Invantive’s SQL-extension synchronize
are given in:
- Synchronize your Data with one Statement across multiple Applications
- Synchronize Exact Online with Visma.net Financials
- Custom logic triggers on data synchronize statement for easier data integration
- Easily determine changed values in custom data-integration triggers with synchronize
Limitations
The SQL driver in release 22.1.155 covers all data types. Only a limited number of Odoo field data types are not available or remain untested in actual test cases:
json
many2one_reference
reference
properties
properties_definition
Availability
DML operations are available starting Invantive SQL BETA 22.1.155.
