Krijg Fortnox-vouchers + script voor vouchers
We (cursor) wrote a small piece of code to retrieve all vouchers + vouchers rows. It works in Invantive’s cloud and has better performance than the view
from   Fortnox.Views.Vouchers
were timeout can often be reached.
create or replace table vouchers@inmemorystorage as
from   Fortnox.Vouchers.Vouchers
       ( 27 -- filter on financial year 2025
-- Let's see the actual structure of the data
from   Fortnox.Vouchers.VoucherLinesByVoucherSeriesAndVoucherNumber
       ( 'A'  -- example voucher series
       , '1'  -- example voucher number
       , 27   -- financial year 2025
-- Now we can create the voucherslines table with the same structure
create or replace table voucherslines@inmemorystorage
( rowid$ integer
, Account varchar(10)
, CostCenter varchar(10)
, Credit decimal(18,2)
, Debit decimal(18,2)
, Description varchar(200)
, Project varchar(10)
, Quantity decimal(18,2)
, Removed boolean
, VoucherNumber varchar(10)
, VoucherSeries varchar(10)
, Year integer
-- Now we can loop through the vouchers and insert their lines
  for r in (select VoucherSeries, VoucherNumber from vouchers@inmemorystorage)
  loop
    insert into voucherslines@inmemorystorage
    select cast(null as integer) as rowid$,
           cast(t.Account as varchar(10)) as Account,
           cast(t.CostCenter as varchar(10)) as CostCenter,
           cast(t.Credit as decimal(18,2)) as Credit,
           cast(t.Debit as decimal(18,2)) as Debit,
           cast(t.Description as varchar(200)) as Description,
           cast(t.Project as varchar(10)) as Project,
           cast(t.Quantity as decimal(18,2)) as Quantity,
           cast(t.Removed as boolean) as Removed,
           cast(t.VoucherNumber as varchar(10)) as VoucherNumber,
           cast(t.VoucherSeries as varchar(10)) as VoucherSeries,
           cast(t.Year as integer) as Year
           ( r.VoucherSeries
           , r.VoucherNumber
           ) t;
  end loop;
-- Join vouchers and voucherslines
select v.*,  -- all columns from vouchers
       vl.*  -- all columns from voucherslines
from   vouchers@inmemorystorage v
join   voucherslines@inmemorystorage vl
  on   v.VoucherSeries = vl.VoucherSeries
  and  v.VoucherNumber = vl.VoucherNumber
order by v.VoucherSeries, v.VoucherNumber;
