Client-side connector for Qlik Sense with Invantive Cloud
Qlik Sense offers many connectors, but not many similar to Invantive Cloud.
Do you want to support this idea for improving Invantive software? Please register/log on first, then add a vote by clicking on the “Vote” button directly to the left of the title above or add a reply.
We would need to know what you are planning exactly, before we can decide if this would help us.
Idea is in votes gathering phase currently, but probably something similar to the proxy for Power BI offered using the OData 4 protocol.
As far as we know they are working on making OData 4 possible in the Qlik Webconnector.
The support for OData v4.0, including JSON responses, is now on track for release in February 2022.
Thanks for additional information on upcoming addition of OData4 to Qlik Sense. In that case, it is maybe better to give it some time since the OData4 protocol has a lot of nifty features in terms of performance and throughput.
Qlik now supports OData 4 JSON since March 5, 2022 Web Connectors release as described in:
and since February on Qlik Sense SaaS.
The use is described with the OData Qlik Web Connector documentation.
However, a (possibly C#) error in Tableau still hinders actual use as described on (status June 2022):
XML foutmelding bij ophalen tabellen
Bij het ophalen van de lijst met tabellen dient u te kiezen voor `` JsonV4ListResourcesen niet voorListResources` (die enkel het verouderde XML ondersteunt):
OutOfMemoryException bij Preview
De Qlik Cloud preview kan een OutOfMemoryException geven bij het previewen. Dit is een preview-only issue. Gelieve de gegevens gewoon te laden. Preview is mogelijk door $top=100 bij de OData options op te geven in previewvenster.
Een bericht is gesplitst naar een nieuw topic: Error ophalen transactionlines
Een andere Qlik-Cloud gebruiker meldde dat het gebruik van de REST-connector i.p.v. de OData4-connector op Qlik Cloud significant stabieler en sneller was. Enige nadeel is dat de volledige URL voor de dataset dan opgegeven moet worden (geen lijst van tabellen).
