Itgenoda061 foutmelding
Helaas opnieuw problemen met 24.0.746.
De melding is:
itgenoda061: Syntax error ‘:’ at position 0.
itgenclr217: The remote server returned an error: (400) Bad Request.
URL:
https://start.exactonline.be/api/v1/970600/salesorder/GoodsDeliveryLines?$select=ID%2CCreated%2CCreatorFullName%2CDeliveryDate%2CDescription%2CDivision%2CEntryID%2CItem%2CItemCode%2CItemDescription%2CLineNumber%2CModified%2CModifier%2CModifierFullName%2CNotes%2CQuantityDelivered%2CQuantityOrdered%2CSalesOrderLineID%2CSalesOrderLineNumber%2CSalesOrderNumber%2CBatchNumbers%2CStorageLocation%2CStorageLocationCode%2CStorageLocationDescription%2CTrackingNumber%2CUnitcode&$expand=BatchNumbers&$filte...D+eq+guid%27cd8f698d-bc30-4162-a121-5dad519d366c%27+and+%28%3A%3Aancestor.%3A%3Aancestor.LineNumber+eq+6+or+%3A%3Aancestor.%3A%3Aancestor.LineNumber+eq+1+or+%3A%3Aancestor.%3A%3Aancestor.LineNumber+eq+4+or+%3A%3Aancestor.%3A%3Aancestor.LineNumber+eq+5+or+%3A%3Aancestor.%3A%3Aancestor.LineNumber+eq+9+or+%3A%3Aancestor.%3A%3Aancestor.LineNumber+eq+3+or+%3A%3Aancestor.%3A%3Aancestor.LineNumber+eq+2+or+%3A%3Aancestor.%3A%3Aancestor.LineNumber+eq+7+or+%3A%3Aancestor.%3A%3Aancestor.LineNumber+eq+8%29
Call stack:
System.Net.WebException
ValidationException
   at Invantive.Data.Providers.Http.HttpBasedProvider.DoRequest(GlobalState owner, ExecutionOptions executionOptions, HttpWebRequest request, String url, ObjectDefinition objectDefinition, QueryObject queryObject, String partitionCode, String callSafeNameOverrule, String anonymizedPostText, Boolean allowRetryOnNoConnectionMade, Boolean allowRetryOnConnectionLoss, ParameterList parameters, Guid nativeCallUid, Boolean throwExceptionOnNonSuccessfulStatusCode, Object requestBody, Int64 timeoutInitialMs, Int64 timeoutMaxOnRetryMs, String resultCacheId, String publicQueryParameters, SqlExecutionStep sqlExecutionStep, ExecutionStatistics& executionStatistics, ODataErrorProcessingInstructions& oDataErrorProcessingInstructions)
Query:
  l_workbook  excel_workbook;
  l_worksheet excel_worksheet;
  l_binary    blob;
  -- Create an Excel workbook.
  l_workbook := excel.new();
  -- Add a worksheet for Exact Online customer labels.
  l_worksheet := excel.add_worksheet
  ( l_workbook
  , 'LABELS'
  -- Create a list of articles.
  create or replace table orderlabels@inmemorystorage
  select   sod.YourRef
           label 'Customer PO'
    ,      sol.CustomerItemCode
             label 'Customer Item'
    ,      sol.ItemCode
             label 'KL Item'
    ,      abs(coalesce(gdr.BnrQuantity, gde.QuantityDelivered)) || ' ' || gde.Unitcode AS quantity_delivered
             label 'Quantity Delivered'
    ,      gdr.BnrBatchNumber
             label 'Batch #'
    ,      sod.DeliverToName
             label 'Customer Name'
    ,      gde.Description
             label 'Item Description'
    ,      '' AS production_date
             label 'Production Dat...dr.EntryId    = gde.EntryId
  and    gdr.LineNumber = gde.LineNumber
  where  sol.DeliveryStatus in (21 /* Complete */, 20 /* Partial */)
  and    sol.InvoiceStatus in (12 /* Open */, 20 /* Partial */)
  and    sol.QuantityDelivered > sol.QuantityInvoiced
  and    sol.QuantityDelivered > 0
  by     sod.DeliverToName
  ,      gde.StorageLocationCode
  ,      gdr.ItemCode
  ,      sod.YourRef
  -- Place the items in the Excel worksheet.
  excel.fill_using_query(l_worksheet, 'select * from orderlabels@inmemorystorage');
  -- Retrieve the resulting XLSX-file.
  l_binary := excel.export_to_xlsx(l_workbook);
  -- Return the XLSX file to the user.
  cloud_http.set_response_body_binary(l_binary);
  cloud_http.set_response_content_type('application/vnd.openxmlformats-officedocument.spreadsheetml.sheet');
  cloud_http.set_response_header_value('Content-Disposition', 'attachment; filename="ORDER LABELS.xlsx"');
Tabel die foutmelding veroorzaakt is ExactOnlineREST.SalesOrder.GoodsDeliveryLineBatchNumbers bij het ophalen van de volgende data-elementen:
BatchNumbers.results[*]
URL:
/api/v1/970600/salesorder/GoodsDeliveryLines?$select=ID,Created,CreatorFullName,DeliveryDate,Description,Division,EntryID,Item,ItemCode,ItemDescription,LineNumber,Modified,Modifier,ModifierFullName,Notes,QuantityDelivered,QuantityOrdered,SalesOrderLineID,SalesOrderLineNumber,SalesOrderNumber,BatchNumbers,StorageLocation,StorageLocationCode,StorageLocationDescription,TrackingNumber,Unitcode&$expand=BatchNumbers&$filter=::ancestor.::ancestor.EntryID eq guid'cd8f698d-bc30-4162-a121-5dad519d366c' and (::ancestor.::ancestor.LineNumber eq 6 or ::ancestor.::ancestor.LineNumber eq 1 or ::ancestor.::ancestor.LineNumber eq 4 or ::ancestor.::ancestor.LineNumber eq 5 or ::ancestor.::ancestor.LineNumber eq 9 or ::ancestor.::ancestor.LineNumber eq 3 or ::ancestor.::ancestor.LineNumber eq 2 or ::ancestor.::ancestor.LineNumber eq 7 or ::ancestor.::ancestor.LineNumber eq 8)
geeft de Exact Online-foutmelding:
  "error": {
    "code": "",
    "message": {
      "lang": "",
      "value": "Syntax error ':' at position 0."
Release 24.0.745
De foutmelding kan eenvoudig opgewekt worden onder 24.0.745 en nieuwer met de volgende query:
from   goodsdeliverylinebatchnumbers
where  linenumber = 1
met de URL:
/api/v1/.../salesorder/GoodsDeliveryLines?$select=...&$expand=BatchNumbers&$filter=::ancestor.::ancestor.LineNumber eq 3
De foutmelding treedt niet op bij de query:
where  entryid = newid()
die ook geen filter gebruikt:
Release 24.0.735
Een vergelijking met versie 24.0.735 van het Invantive Query Tool levert als URL voor de eerste query:
/api/v1/.../salesorder/GoodsDeliveryLines?$select=...&$expand=BatchNumbers&$filter=LineNumber eq 1
en bij de tweede query een ongewijzigde URL tussen de twee versies.
Analyse
Verwachting is dat probleem specifiek en enkel betrekking heeft op de serienummers en batchnummers van goederenleveringen. Deze API’s wijken serieus af van vrijwel alle andere API’s.
Een analist zal deze week dit punt bestuderen om te komen tot een oplossing.
Vanaf de volgende 25.0-release zal deze specifieke foutmelding specifieker gelabeld worden met itgeneor843.
Betekent dit dat wij niet meer verder kunnen?
Wij gebruiken dit iedere dag een 20-tal keer.
Kan de versie niet teruggedraaid worden zolang er geen oplossing is?
Een versieteruggang bleek niet haalbaar vanwege andere benodigde wijzigingen, mede in aanloop naar zomer freeze.
Een nieuwe release 24.0.748 is in productie genomen op Invantive Cloud die dit probleem zou moeten oplossen.
