When executing a PSQL module on Invantive Cloud, I receive always the following error:
itgensql169:
Row is required to retrieve string value of variable ‘p_actord_code’ at index 7. (p_actord_code).
How do I fix this?
The code contains p_actord_code in:
p_account_code varchar2 := null;
and actord.code = coalesce(p_actord_code, actord.code)
-- Filter on ordering customer code and/or name.
and ( p_actord_code is null
or
( p_actord_code is not null
and sie.orderedby
in
( select /*+ low_cost */ act.id
from accountsBulk@eol act
where act.code = p_actord_code
or
and sie.orderedby
in
uses the low_cost hint which executes very early at module start, before the module is set up. The value is only available on the next SQL-batch.
Recommendation is to not use low_cost with a parameter in the where-clause, but to rephrase to:
l_orderedby guid;
if p_actord_code is not null
then
select act.id
into l_orderedby
else
l_orderedby := null;
end if;
or
( p_actord_code is not null and sie.orderedby = l_orderedby )
This avoids the too early execution of the low_cost marked sub-query.
The error code could be more clear and concise to indicate the cause. We will study a better alternative.
