3- API call cost
what would be the API Call cost of statement like this : select * from BalanceLinesEx@eol
I could not find this in the Exact documentation API Limits, nor any page size information like in the REST API.
It seems that the manual export might generate multiple xml files, so I would say that 1 file = 1 API call.
Also could you inform if the select * from Ratelimits@eol has been replaced by another command?
Default for previous years is 2, and the maximum is 5 (although undocumented it seems). When more than 5 years are needed, vary Params_Year.
The API call cost of the XML-tables is indeed 1 API call per XML file download. Each XML API returns typically 100 XML root nodes per request, but there can be many rows derived from it often. So, they are in general a lot faster and consume less API calls than similar REST APIs.
In general we strongly recommend to use the following financial XML APIs: BalanceLinesPerPeriod, APOutstandingItems and AROutstandingItems. For all other use, the REST APIs provide better/more flexible alternatives.
