Verifymail.io queryen met SQL-instructies
This topic explains how to use Invantive SQL (Structured Query Language) to interact with the API of the verifymail.io service to verify email addresses and domains to exclude temporary/one-time email addresses, domains without MX record and proxy email domains. A check helps ensure that an email address can be traced to a physical person in environments with high integrity requirements.
Verifymail.io does not assess whether an email domain is for business or consumer use. For this purpose, https://www.ipqualityscore.com might be more suitable (5000 credits monthly in Free Plan, paid plans start at USD 499 monthly).
Verifymail.io API provides a simple API using key-based authentication. Documentation on the API can be found on https://verifymail.io/api-documentation. A free plan is available for at most 3 calls per day (paid plans start at USD 25 monthly).
Basis for the explanation is an Excel spreadsheet ‘domains.xlsx’ with a sheet ‘Sheet1’ with the following contents:
A
1 Domain
2 nu.nl
3 nos.nl
4 facebook.com
5 … etc …
The following query first retrieves the contents of the Excel-sheet starting at row 2, and the queries the verifymail.io API service for each domain, parses the JSON and stores the results as table DomainScan@InMemoryStorage:
create or replace table DomainScan@InMemoryStorage
select jte.*
from   exceltable
       ( worksheet 'Sheet1'
         passing file 'c:\PATH\domains.xlsx'
         skip first 1 rows
         columns domein varchar2 position next
       ) ete
join   httpdownload@DataDictionary
       ( url => 'https://verifymail.io/api/' || ete.domein || '?key=SECRETAPIKEY'
       , diskCache => true
       , diskCacheMaxAgeSec => 86400 * 7
       , ignoreWebError => true
       ) htp
on     htp.http_status_code = 200
join   jsontable
         passing htp.contents_char
         columns block             boolean  path 'block'
         ,       disposable        boolean  path 'disposable'
         ,       deliverable_email boolean  path 'deliverable_email'
         ,       catch_all         boolean  path 'catch_all'
         ,       privacy           boolean  path 'privacy'
         ,       domain            varchar2 path 'domain'
         ,       email_address     varchar2 path 'email_address'
         ,       related_domains   varchar2 path 'related_domains'
         ,       mx_priority       varchar2 path 'mx_priority'
         ,       mx_ip             varchar2 path 'mx_ip'
         ,       mx_host           varchar2 path 'mx_host'
         ,       mx_fallback       boolean  path 'mx_fallback'
         ,       mx                boolean  path 'mx'
         ,       email_provider    varchar2 path 'email_provider'
       ) jte
The results can be queried using:
from   DomainScan@InMemoryStorage
with results:
Please note that verifymail.io allows a limited number of API calls per month, depending on the plan. For performance and cost reasons, it is wise to cache the outcome of the verifymail.io API-calls depending on your use case.
