A driver for Intacct would be appreciated.
Documentation: API Reference | Sage Intacct Developer
Authentication seems to similar to Bluem and WS-Security using sender, password and timestamp.
Authentication described on:
Either login authentication or session authentication is possible.
Payload using XML. Paging using pagesize, offset and orderby. Server-side filtering using filteroption.
Not sure if I understand the solution. Is it easy to build a flow from Jira to Intacct just for billing modular? And how to.
Thank you.
It is currently solely registered as an idea for future developments, therefore the category “Ideas (en)”.
