SQL-driver officielebekendmakingen.nl
The site zoek.officielebekendmakingen.nl serves publications from governmental organisations.
It can be accessed as described in:
It would be handy for statistical analyses when a driver would be available.
There are three sample cases for which data extraction should be possible using Invantive UniversalSQL.
Case 1 - simple
A request for a permit. No external documents, no additional documents.
See also:
Case 2 - external documents
A request for a permit. With external documents, no additional documents.
There are two external documents in this sample:
See also:
Case 3 - bundled documents
A decision on the Omgevingswet. No external documents, with additional documents (available for inspection, “terinzagelegging”).
The documents should be queryable:
See also:
Search Options
For statistical purposes, queries should be possible using CQL, either providing the CQL as a table function parameter or maybe even as a server-side filter.
For example, the following searches for publications with a title containing both “julianalaan” as well as “123”, created by “Ermelo”:
https://repository.overheid.nl/sru?maximumRecords=1000&query=(c.product-area==officielepublicaties%20AND%20dt.title=julianalaan%20AND%20dt.creator=Ermelo%20AND%20dt.title=123)
CQL is defined in:
A number of drivers are considered for being added:
  • Officiele Publicaties (identifier “officielepublicaties”),
  • Samenwerkende Catalogi,
  • SG Digitaal,
  • Tuchtrecht,
  • Verdragenbank,
  • PLOOI (allegedly failed).
The following additions might be added also, although they are likely to have a different format:
  • CVDR
  • BWB
  • Europese Richtlijnen
  • PUC Open Data
  • Wetgevingskader
  • Staatsalmanak (overheidsorganisaties)
The following drivers have been made available starting release 24.0.740:
  • SG Digitaal,
  • Tuchtrecht,
  • Verdragenbank,
Known issues are:
  • reference tables only contain 10 rows
  • external and linked documents not available
Both might be solved in a future release.
