Voeg een filter toe op veld-ID en waarde voor ContactCustomFieldValues voor betere prestaties
We have say 100 custom fields and say 100.000 contacts in ActiveCampaign. To speed up retrieval of the value for a specific custom field we would like to be able to filter on the custom field ID as a table function parameter.
That is currently not possible.
Can that table function parameter be added to ContactCustomFieldValues?
Most expressions on field with ContactWithCustomFieldValues are now server-side forwarded. For instance, the following query retrieves only field 15:
select count(*)
from   contactwithcustomfieldvalues
where  field = 15
Please apply a filter step in Power BI using query folding to enjoy the improved performance.
