The following article shows how to convert the XML in a Wix translation files with extension *.wxl into a table for use in SQL queries.
Wix can be translated into many languages using translation files. Per language or culture there is a single XML file with extension .wxl. All translation files are gathered in a single folder. The contents of each file resembles the following structure:
<WixLocalization Culture="en-US" Codepage="1252" xmlns="http://wixtoolset.org/schemas/v4/wxl">
<String Id="WixUIBack" Overridable="yes">&Back</String>
<String Id="WixUINext" Overridable="yes">&Next</String>
The following query can be used to process the data into a table:
create or replace table WixTranslationKeys@InMemoryStorage
select xte.*
from files@os('C:\Users\gle3.WS212\Documents\ws-other\UI.wixext\src\wixlib', 'wixui*.wxl', false) fle
join read_file_text@os(fle.file_path) rft
join xmltable
( '//*["String"=local-name()]'
passing rft.file_contents
columns cultureCode varchar2 path '../@Culture'
, id varchar2 path '@Id'
, txt varchar2 path 'text()'
) xte
The use of `[“String”=local-name()]" circumvents specification of namespaces.
A sample of the results are displayed below:
