Variabelen declareren en doorgeven tussen niet-geneste blokken
I would like to know if there is a possibility to use variables across non-nested begin...end; blocks.
Because the way Invantive parses scripts that includes create or replace table and subsequent access to theses created table, I cannot use a unique begin...end; nor nested ones as discussed here: SQL strange behaviour with a begin + loop + create or replace @inmemorystorage - 7 van forums
For exemple, creating a log, that will be afterwards saved thanks to write_file@Os
-- block1
  l_log_txt varchar2;
    l_log_txt := l_log_txt + (chr(10) || 'script started at : ' || sysdate);
    -- do things here like create or replace a table
-- block2
--declare l_log_txt varchar2;
  l_log_txt := l_log_txt + (chr(10) || 'script finished at : ' || sysdate);
  -- do things here like read, insert or else on the above table
-- block3
  insert into write_file@Os
  ( file_path
  , file_contents
  values
  ( 'c:\jobs\log\log.txt'
  , base64_encode(ascii_to_blob(l_file_content))
Of course a workaround could be creating a inmemory table
create or replace table variables@inmemorystorage
( var_name varchar2
, var_value varchar2
to store variables. But it is not very easy to manipulate … when inserting, reading and updating values.
There is currently no way to store state easily in the session across PSQL-blocks other than through storing it in an in-memory or other table.
A good example is shown in Easily determine changed values in custom data-integration triggers with synchronize.
In the future, the package concept might be extended to allow defining your own packages. In that case, there might be variables available to store data in from outside the package or through a function in the package, just like with the dbms_output package.
