Itgenpse031: Fout op regel [...] Variabele met de naam '***' is al gedeclareerd komt voor wanneer 2 lussen in dezelfde instructie staan
Good afternoon,
there is as small code deviation issue I found in 22.0.330. I’m not sure since when.
when there are 2 loop statement with the same loop variable, Invantive says it is already declared.
it seems that the exec tries to declare it 2 times, since there are two loops whereas it was not the case in the past
for the time being, the turnaround is to use a different named loop variable in the second loop.
example:
create or replace table mytable@inmemorystorage (v varchar2);
insert into mytable@inmemorystorage (v) values ('value1');
insert into mytable@inmemorystorage (v) values ('value2');
insert into mytable@inmemorystorage (v) values ('value3');
l_store varchar2;
for r in (select * from mytable@inmemorystorage)
loop
  l_store := l_store || r.v
end loop;
loop
end loop;
turnaround
 l_store varchar2;
loop
end loop;
for f in (select * from mytable@inmemorystorage)
loop
  l_store := l_store || f.v
end loop;
Thanks for your post. You are correct this is the current behavior, which was introduced somewhere this year. There is no solution in the short term to fix this unpreferred behavior.
Please change your scripts as you already have done.
