Encountered a property 'R_F0_C_#1' that was expected to be a reference to a location in the $metadata document but does not contain a '#' character or is otherwise not a valid metadata reference property
On downloading a dataset from Knack, I receive the following error:
DataSource.Error: OData:
Encountered a property ‘R_F0_C_#1’ that was expected to be a reference to a location in the $metadata document but does not contain a ‘#’ character or is otherwise not a valid metadata reference property.
A metadata reference property must contain a ‘#’ and be a valid absolute URI or begin with a ‘#’ and be a valid URI fragment.
Details:
DataSourceKind=OData
DataSourcePath=https://bridge-online-beta.invantive.com/acme-knack/odata4/Knack.Objects.History_Logs@knk
How can I download this table?
Please use app-online.cloud instead of bridge-online.cloud. For instance:
https://app-online.cloud/acme-partners-knack/odata4
The Bridge Online has (for compatibility with existing queries) some limitations for special characters.
