Extract spreadsheet with translations for Bluesky from Localazy
This topic describes how to create a spreadsheet for reviewing purposes of the translation of Bluesky from English into Dutch.
Localazy uses tokens which allow access to one specific project. Such a token can be retrieved from https://localazy.com/console/tokens. However, Localazy also supports an organization token, which allow access to ALL projects of a subscription.
Start the Invantive Query Tool or Invantive Cloud. Then connect to Localazy using the chosen token (either for the project or the organization token). In this sample Invantive Query Tool will be used with an organization token:
The first query is to check whether the project is indeed accessible using the organization token:
from   projects
where  slug = 'bsky'
Note that each SQL-statement is rewritten by the SQL engine and Localazy-driver into one or more API calls to Localazy. These calls can be found also in the SessionIOs@DataDictionary table and SQL execution steps.
The Bluesky translation project is indeed available:
Download Glossary to Excel
First, we will retrieve the glossary, so the reviewer knows what standard translations have applied and how words have been interpreted:
select pgn_en.term
       term_en
       label 'English Term'
,      pgn_nl.term
       term_nl
       label 'Dutch Term'
,      pgm.translateTerm
       label 'Translate to Other Languages?'
,      pgm.caseSensitive
       label 'Case-sensitive?'
,      pgm.exactMatch
       label 'Exact Match?'
,      pgm.description
       label 'Definition'
from   ProjectGlossaryTerms pgm
join   ProjectGlossaryTermTranslations pgn_en
on     pgn_en.lang = 'en'
and    pgn_en.term_id = pgm.id
join   ProjectGlossaryTermTranslations pgn_nl
on     pgn_nl.lang = 'nl'
and    pgn_nl.term_id = pgm.id
where  pgm.project_slug = 'bsky'
by     pgn_en.term
The result is:
The Excel-file can be created using the export button, the for excel clause or using the Invantive Script statement local export results.
Export Translations
In the next step, the translations for the Bluesky resources will be exported to Excel. Note that Bluesky uses the English text as a resource key, so only the key plus the Dutch translation are needed for a review.
The query is:
select pfy.keys
,      pfy.value
,      comment
from   ProjectFileKeys pfy
where  pfy.project_slug  = 'bsky'
and    pfy.language_code = 'nl'
by     pfy.keys
with results:
