hli8
November 27, 2023, 4:04pm
1
I am able to retrieve tickets from JIRA-tables, but I seem unable to find values for the custom fields defined on https://acme.atlassian.net/secure/admin/ViewCustomFields.jspa.
For instance, we have a field “Billable” as shown below as custom field.
How do I get to see it’s value?
forums
December 1, 2023, 8:42am
2
Thanks for your question. We are studying what the best way is to include custom fields more abundantly in the predefined tables.
Could you execute the following query in the UniversalSQL editor on your JIRA-database, and then indicate whether the suggested column names in the third column (suggestedFieldName) would match your needs?
Please export the results to Excel in the UniversalSQL-editor, remove all rows matching your needs and copy&paste the remainder from Excel to your reply.
select fld.id
, fld.schema_type
, 'c_'
|| replace
( case
when fld.key like 'customfield_%'
or fld.key like '%-custom-field'
then lower(coalesce(names.clauseNamesList, fld.key))
when fld.key like 'com.atlassian.atlas.jira__%'
then replace(fld.key, 'com.atlassian.atlas.jira__', 'jira_')
when fld.key like 'io.tempo.jira__%'
then replace(fld.key, 'io.tempo.jira__', 'tempo_')
else fld.key
end
, ' ', '_'
, '-', '_'
suggestedFieldName
, fld.name
, names.clauseNamesList
--, fld.schema_items
--, fld.schema_system
from fields fld
left
outer
join ( select field_id
, listagg(clauseName) clauseNamesList
, count(*) clauseNamesCount
from fieldclauses
where clauseName not like '%[%'
group
by field_id
) names
on names.field_id = fld.id
where 1=1
and fld.schema_type not in ('array', 'sd-approvals')
and fld.custom
by id
The output should resemble the following (output from a test database):
id
schema_type
suggestedFieldName
name
clauseNamesList
aggregateprogress
progress
c_aggregateprogress
Σ Voortgang
aggregatetimeestimate
number
c_aggregatetimeestimate
Σ Resterende schatting
aggregatetimeoriginalestimate
number
c_aggregatetimeoriginalestimate
Σ Oorspronkelijke schatting
aggregatetimespent
number
c_aggregatetimespent
Σ Bestede tijd
assignee
user
c_assignee
Uitvoerder
assignee
comment
comments-page
c_comment
Opmerking
comment
created
datetime
c_created
Aangemaakt
created, createdDate
creator
user
c_creator
Ontwikkelaar
creator
customfield_10000
datetime
c_ Needs work
[CHART] Date of First Response
customfield_10001
any
c_ Needs work
[CHART] Time in Status
customfield_10016
any
c_epic_link
Epic Link
Epic Link
customfield_10017
option
c_epic_status
Epic Status
Epic Status
customfield_10018
string
c_epic_name
Epic Name
Epic Name
customfield_10019
string
c_epic_color
Epic Color
Epic Color
customfield_10020
any
c_rank
Rank
Rank
customfield_10022
number
c_story_points
Story Points
Story Points
customfield_10100
any
c_parent_link
Parent Link
Parent Link
customfield_10200
any
c_development
development
development
customfield_10400
any
c_team
Team
Team
customfield_10600
number
c_value_initial
Value Initial
Value Initial
customfield_10601
number
c_value_recurring
Value Recurring
Value Recurring
customfield_10700
date
c_start_date
Start date
Start date
customfield_10701
sd-customerrequesttype
c_request_type
Request Type
Request Type
customfield_10703
number
c_story_point_estimate
Story point estimate
customfield_10704
string
c_issue_color
Issue color
Issue color
customfield_10705
sd-feedback
c_satisfaction
Satisfaction
Satisfaction
customfield_10706
datetime
c_satisfaction_date
Satisfaction date
Satisfaction date
customfield_10708
option
c_impact
Impact
Impact
customfield_10709
option
c_change_type
Change type
Change type
customfield_10710
option
c_change_risk
Change risk
Change risk
customfield_10711
option
c_change_reason
Change reason
Change reason
customfield_10712
datetime
c_change_start_date
Change start date
Change start date
customfield_10713
datetime
c_change_completion_date
Change completion date
customfield_10714
option
c_urgency
Urgency
Urgency
customfield_10717
option
c_pending_reason
Pending reason
Pending reason
customfield_10718
option-with-child
c_product_categorization
Product categorization
customfield_10719
option-with-child
c_operational_categorization
Operational categorization
customfield_10720
option
c_source
Source
Source
customfield_10721
option
c_investigation_reason
Investigation reason
customfield_10722
string
c_root_cause
Root cause
Root cause
customfield_10723
string
c_workaround
Workaround
Workaround
customfield_10724
sd-servicelevelagreement
c_time_to_resolution
Time to resolution
Time to resolution
customfield_10725
c_time_to_first_response
Time to first response
customfield_10726
c_time_to_close_after_resolution
Time to close after resolution
customfield_10727
c_time_to_approve_normal_change
Time to approve normal change
customfield_10728
sd-request-lang
c_request_language
Request language
Request language
customfield_10729
date
c_next_review_date
Next Review Date
Next Review Date
customfield_10730
string
c_agreement_code
Agreement Code
Agreement Code
customfield_10731
option2
c_tempo_team
Tempo Team
Tempo Team
customfield_10732
option2
c_tempo_account
Account
Account
customfield_10735
string
c_waarde_verkoopkans
Waarde verkoopkans
Waarde verkoopkans
customfield_10736
date
c_target_start
Target start
Target start
customfield_10737
date
c_target_end
Target end
Target end
customfield_10738
c_tijd_tot_oplossing
Tijd tot oplossing
Tijd tot oplossing
customfield_10739
c_tijd_tot_eerste_reactie
Tijd tot eerste reactie
customfield_10740
string
c_contenttype
Contenttype
Contenttype
customfield_10741
date
c_publicatiedatum
Publicatiedatum
Publicatiedatum
customfield_10745
string
c_work_category
Work category
Work category
customfield_10746
number
c_open_forms
Open forms
Open forms
customfield_10747
number
c_submitted_forms
Submitted forms
Submitted forms
customfield_10748
number
c_locked_forms
Locked forms
Locked forms
customfield_10749
number
c_total_forms
Total forms
Total forms
customfield_10750
string
c_compass
Compass
Compass
customfield_10751
option
c_categorie
Categorie
Categorie
customfield_10752
string
c_belangrijk_incident
Belangrijk incident
Belangrijk incident
customfield_10753
option
c_ernst
Ernst
Ernst
customfield_10754
string
c_getroffen_hardware
Getroffen hardware
Getroffen hardware
customfield_10755
datetime
c_geplande_start
Geplande start
Geplande start
customfield_10756
datetime
c_gepland_einde
Gepland einde
Gepland einde
customfield_10757
string
c_implementatieplan
Implementatieplan
Implementatieplan
customfield_10758
string
c_backout-plan
Backout-plan
Backout-plan
customfield_10759
string
c_testplan
Testplan
Testplan
customfield_10760
string
c_jira_project_key
Atlas project key
Atlas project key
customfield_10761
string
c_jira_project_status
Atlas project status
customfield_10762
string
c_department
Department
Department
description
string
c_description
Beschrijving
description
duedate
date
c_duedate
Vervaldatum
due, duedate
environment
string
c_environment
Omgeving
environment
issuerestriction
issuerestriction
c_issuerestriction
Voorbehouden voor
issuetype
issuetype
c_issuetype
Issuetype
issuetype, type
lastViewed
datetime
c_lastViewed
Laatst Bekeken
lastViewed
priority
priority
c_priority
Prioriteit
priority
progress
progress
c_progress
Vooruitgang
progress
project
project
c_project
Project
project
reporter
user
c_reporter
Melder
reporter
resolution
resolution
c_resolution
Resolutie
resolution
resolutiondate
datetime
c_resolutiondate
Opgelost
resolutiondate, resolved
security
securitylevel
c_security
Beveiligingsniveau
level
status
status
c_status
Status
status
statuscategorychangedate
datetime
c_statuscategorychangedate
Statuscategorie gewijzigd
statusCategoryChangedDate
summary
string
c_summary
Samenvatting
summary
timeestimate
number
c_timeestimate
Resterende Schatting
remainingEstimate, timeestimate
number
c_timeoriginalestimate
originalEstimate, timeoriginalestimate
timespent
number
c_timespent
Tijd gespendeerd
timespent
timetracking
timetracking
c_timetracking
Tijdregistratie
updated
datetime
c_updated
Bijgewerkt
updated, updatedDate
votes
votes
c_votes
Stemmen
votes
watches
watches
c_watches
Kijkers
watchers
workratio
number
c_workratio
Werkratio
workratio
Invantive’s SQL JIRA-drivers in release 24.0 have been extended by December 2023 to include all custom field values as columns.
Please use a recent 24.0 release such as on Invantive Cloud.
