Itgeneor328 "A required filter is missing" bij SalesOrdersBulk
Bij replicatie van ExactOnlineREST.SalesOrder.SalesOrdersBulk treedt volgende melding op in Invantive Data Hub 22.1.122-BETA+3759:
2023-01-11 00:44:09.988 Error itgencun016: Error itgeneor328: Multiple errors in Invantive Data Hub.
One or more errors occurred.
A required filter is missing.
Please contact Invantive Support: This endpoint has mandatory filtering applied. A GET request for this endpoint must have a $filter parameter with one of the following fields in the url:ApprovalStatus,Approver,Created,DeliverTo,DeliverToContactPerson,DeliveryAddress,DeliveryDate,DeliveryStatus,Description,Document,InvoiceStatus,InvoiceTo,InvoiceToContactPerson,Modified,OrderedBy,OrderedByContactPerson,OrderDate,OrderID,OrderNumber,Salesperson,SelectionCode,ShippingMethod,Status,TaxSchedule,PaymentReference,WarehouseID,YourRef.
Please contact Invantive Support: This endpoint has mandatory filtering applied. A GET request for this endpoint must have a $filter parameter with one of the following fields in the url:Created,DeliverTo,DeliverToAddress,DeliverToContactPerson,Description,Document,InvoiceDate,InvoiceID,InvoiceNumber,InvoiceTo,InvoiceToContactPerson,Journal,Modified,OrderedBy,OrderedByContactPerson,OrderNumber,PaymentReference,Salesperson,SelectionCode,Status,TaxSchedule,Type,YourRef,Warehouse.
Please contact Invantive Support: This endpoint has mandatory filtering applied. A GET request for this endpoint must have a $filter parameter with one of the following fields in the url:Barcode,Class_01,Class_02,Class_03,Class_04,Class_05,Class_06,Class_07,Class_08,Class_09,Class_10,Code,CostPriceNew,Created,Description,EndDate,ExtraDescription,FreeBoolField_01,FreeBoolField_02,FreeBoolField_03,FreeBoolField_04,FreeBoolField_05,FreeDateField_01,FreeDateField_02,FreeDateField_03,FreeDateField_04,FreeDateField_05,FreeNumberField_01,FreeNumberField_02,FreeNumberField_03,FreeNumberField_04,FreeNumberField_05,FreeNumberField_06,FreeNumberField_07,FreeNumberField_08,FreeTextField_01,FreeTextField_02,FreeTextField_03,FreeTextField_04,FreeTextField_05,FreeTextField_06,FreeTextField_07,FreeTextField_08,FreeTextField_09,FreeTextField_10,GLCosts,GLRevenue,GLStock,ID,IsBatchItem,IsFractionAllowedItem,IsMakeItem,IsPurchaseItem,IsSalesItem,IsSerialItem,IsStockItem,IsSubcontractedItem,IsTime,IsWebshopItem,ItemGroup,ItemGroupCode,Modified,NetWeightUnit,SalesVatCode,SearchCode,StartDate,Unit.
https://start.exactonline.nl/api/v1/2504981/bulk/SalesOrder/SalesOrders?$select=SelectionCode,SelectionCodeCode,SelectionCodeDescription,AmountDC,AmountDiscount,AmountDiscountExclVat,AmountFC,AmountFCExclVat,ApprovalStatus,ApprovalStatusDescription,Approved,Approver,ApproverFullName,Created,Creator,CreatorFullName,Currency,DeliverTo,DeliverToContactPerson,DeliverToContactPersonFullName,DeliverToName,DeliveryAddress,DeliveryDate,DeliveryStatus,DeliveryStatusDescription,Description,Discount,Division,Document,DocumentNumber,DocumentSubject,InvoiceStatus,InvoiceStatusDescription,InvoiceTo,InvoiceToContactPerson,InvoiceToContactPersonFullName,InvoiceToName,Modified,Modifier,ModifierFullName,OrderDate,OrderID,OrderNumber,OrderedBy,OrderedByContactPerson,OrderedByContactPersonFullName,OrderedByName,PaymentCondition,PaymentConditionDescription,PaymentReference,Remarks,Salesperson,SalespersonFullName,ShippingMethod,ShippingMethodDescription,Status,StatusDescription,TaxSchedule,TaxScheduleCode,TaxScheduleDescription,WarehouseCode,WarehouseDescription,WarehouseID,YourRef,SalesChannel,SalesChannelCode,SalesChannelDescription,IncotermAddress,IncotermCode,IncotermVersion
Call stack:
2023-01-11 00:44:12.050 Error itgeneor328: System.Net.WebException
ValidationException
ValidationException
   at Invantive.Data.Providers.Http.HttpBasedProvider.DoRequest(GlobalState owner, ExecutionOptions executionOptions, HttpWebRequest request, String url, ObjectDefinition objectDefinition, QueryObject queryObject, String partitionCode, String callSafeNameOverrule, String anonymizedPostText, Boolean allowRetryOnNoConnectionMade, Boolean allowRetryOnConnectionLoss, ParameterList parameters, Guid nativeCallUid, Boolean throwExceptionOnNonSuccessfulStatusCode, Object requestBody, Int32 timeoutInitialMs, Int32 timeoutMaxOnRetryMs, String resultCacheId, String publicQueryParameters, ExecutionStatistics& executionStatistics, ODataErrorProcessingInstructions& oDataErrorProcessingInstructions)
ValidationException
ValidationException
System.AggregateException
ValidationException
Gebruikte URL:
/api/v1/410738/bulk/SalesOrder/SalesOrders?$select=SelectionCode,SelectionCodeCode,SelectionCodeDescription,AmountDC,AmountDiscount,AmountDiscountExclVat,AmountFC,AmountFCExclVat,ApprovalStatus,ApprovalStatusDescription,Approved,Approver,ApproverFullName,Created,Creator,CreatorFullName,Currency,DeliverTo,DeliverToContactPerson,DeliverToContactPersonFullName,DeliverToName,DeliveryAddress,DeliveryDate,DeliveryStatus,DeliveryStatusDescription,Description,Discount,Division,Document,DocumentNumber,DocumentSubject,InvoiceStatus,InvoiceStatusDescription,InvoiceTo,InvoiceToContactPerson,InvoiceToContactPersonFullName,InvoiceToName,Modified,Modifier,ModifierFullName,OrderDate,OrderID,OrderNumber,OrderedBy,OrderedByContactPerson,OrderedByContactPersonFullName,OrderedByName,PaymentCondition,PaymentConditionDescription,PaymentReference,Remarks,Salesperson,SalespersonFullName,ShippingMethod,ShippingMethodDescription,Status,StatusDescription,TaxSchedule,TaxScheduleCode,TaxScheduleDescription,WarehouseCode,WarehouseDescription,WarehouseID,YourRef,SalesChannel,SalesChannelCode,SalesChannelDescription,IncotermAddress,IncotermCode,IncotermVersion
Advies is om te wisselen naar de productierelease 22.0. Het probleem in 22.1-BETA zal onderzocht worden.
Alternatief is om gebruik te maken van SalesOrderLinesV2Incremental.
Probleem is reproduceerbaar via de URL https://start.exactonline.nl/api/v1/10523/bulk/SalesOrder/SalesOrders?$select=SelectionCode,...,IncotermVersion via het Invantive Query Tool met de volgende SQL-query:
select * from ExactOnlineREST..SalesOrdersBulk@eol
De foutmelding itgeneor328 treedt alleen op in BETA-versies tot/met release 22.1.122. Dit probleem is verholpen met ingang van BETA-versie 22.1.123 die in de loop van deze week beschikbaar zal komen.
