Itgenobr298 bij inloggen met Data Hub na upgrade naar Exact Online Premium
An update on how to connect to Exact Online Premium would be much appreciated. Our company moved yesterday from PRO to PREMIUM.
We are unsure how we should update all our Invantive scripts and connections/settings.xml, getting:
itgenobr298:
Unexpected redirect to login screen.
Please verify that the multi-platform variant of Invantive Data Hub or Invantive Bridge is being used instead of the .net framework variant.
Message ID: 0dcb6d55-af0f-48c0-8b50-551ca88e468b`
Regarding the itgenobr298 error:
One Exact Identity will probably be used for this specific data load. Specifically, One Exact Identity does not work with Microsoft .net framework version v4.8. One Exact Identity and in particular the MFA elements are based on Azure B2C.
Using Exact Online with Exact Online’s own user directory does work with Microsoft .net framework v4.8.
It is advisable to switch to the multi-platform variant as described in:
This error occurs on QueryTool, not DataHub
OK, that is something we are not aware of. itgenobr298 is from the OAuth background provider, which should only be available on Data Hub for log on to Exact Online. The browser-based authentication provider should be used on the Query Tool.
Can you share a screenshot of the error window of Query Tool with this error, including the title bar and the details expanded, for analysis?
