Kan partities niet selecteren (itgengpr015)
In response to this topic: Selecting partitions/administrations via the use SQL statement.
How would this statement work for Twinfield? I have tried the following two, but without success:
use
select PROVIDER_DATA_CONTAINER_ALIAS
from   DataDictionary.Invantive.SYSTEMPARTITIONS@DataDictionary
where  short_name not in (company_code)
resulting in:
itgencun016:
itgengpr012:
Can not change active partitions to tfd since the partition ‘tfd’ does not exist.
Choose a set of only authorized and licensed partitions.
And:
use
select code
,      'tfd'
from   SystemDivisions@tfd
where  code not in (company_code)
resulting in:
itgencun016
itgengpr015
Unknown table ‘SYSTEMDIVISIONS’.
Possible valid alternatives: Twinfield.Twinfield.DistributionByPeriods, Twinfield.Twinfield.AnnualReportTotalsMulticurrency, Twinfield.Twinfield.Declarations.
The first alternative can be reformulated as:
use
select code
,      PROVIDER_DATA_CONTAINER_ALIAS
since use with a SQL statement always requires specification of the alias, but only after specifying the partition code.
The second one can be reformulated as:
use
select code
,      'tfd'
from   Offices@tfd
using Twinfield’s own specific list of companies instead of a generalized tables SystemPartitions@DataDictionary.
