Optionele vermindering van transportversleuteling voor SQL Server, PostgreSQL en MySQL
By default, Invantive UniversalSQL requires all database connections to apply encryption by TLS (Transport Layer Security). This makes it quite hard for prying eyes along the transport route to see and/or alter your data, similar to HTTPS.
This requirement holds for both on-premises as online use.
However, some cloud platforms and/or hosting parties did not or only partially implement TLS for database connections.
Online
For online use, Invantive Cloud now allows reduction of TLS on creation of a database for SQL Server, PostgreSQL and MySQL. To disable certifate validation, use “Encrypt” instead of “Encrypt and validate server certificate” as shown below:
Transport encryption can even be disabled completely by selecting “Do not encrypt”.
On-premises
For on-premises use, the following articles describes how to disable TLS:
Warning
The use of unsecured data connections makes it more likely that third parties controling devices along your data path (such as routers) can access and/or change the data transported. Please consult your local security officer for advice.
