Bestanden uitwisselen met AWS S3 via Invantive's UniversalSQL
AWS Simple Storage Service (S3) for Data Storage
Invantive UniversalSQL has allowed storage of binary objects in tables for years. However, with increasing volumes of data processed and stored for long periods, a specific store for such BLOBs scales better for lower cost.
AWS provides the Simple Storage Service (“S3”). AWS S3 combines low cost, extreme scalability and high parallel performance. AWS S3 is accessible through an API.
This topic explains how to exchange binary data through the AWS S3 APIs using familiar Invantive UniversalSQL and PSQL-statements.
The associated package aws_s3 is available for use in all free and premium subscriptions starting release 24.0 and 23.1.240-BETA.
Configure AWS S3
The first step is to configure the AWS S3 credentials using aws_s3.configure:
  l_client aws_s3_client;
  l_client := aws_s3.configure
  ( 'eu-west-1' /* Or another region. */
  , 'AK...token to identify...NS'
  , 'wj9...some secret token...UW'
The AWS S3 configuration can also be taken from system-wide settings unless Invantive UniversalSQL runs on a infrastructure shared with other companies. In that case, the configuration is enforced to have be done using aws_s3.configure.
Download Data using SQL with AWS S3
To download data with AWS S3 with SQL-statements the following code can be executed:
  l_payload blob;
  ... call to aws_s3.configure
  -- Download binary data from S3.
  l_payload := aws_s3.download_object
  ( l_client
  , 'my-bucket-name'
  , 'my-file.txt'
Upload Data from SQL to AWS S3
To upload data to AWS S3 with SQL-statements the following code can be executed:
  l_payload blob;
  -- Upload all files in a folder to AWS S3.
  for r
  in
  ( select basename(fle.file_path) key
    ,      rfe.file_contents payload
    from   files@os('c:\temp', '*.pdf', false) fle
    join   read_file@os(fle.file_path) rfe
    on     rfe.file_contents is not null
  loop
    dbms_output.put_line('Upload ' || r.key);
    aws_s3.upload_object(l_client, 'my-bycket-name', r.key, r.payload);
  end loop;
Copy an Object
To copy an object within or across buckets, the following code can be used:
  -- Copy data between S3 buckets or within an S3 bucket.
  aws_s3.copy_object
  ( l_client
  , 'source-bucket-name'
  , 'my-file.txt'
  , 'target-bucket-name'
  , 'folder/my-file.txt'
  -- Optional storage class.
  -- Optional content type.
Retrieve List of (Directory) Buckets
To retrieve the list of buckets in AWS S3, the following code can be used:
  for r
  in
  ( select name
    ,      creation_date
    from   table(aws_s3.list_buckets(l_client))
  loop
    dbms_output.put_line(r.name);
  end loop;
Create Table with Objects Stored in Bucket
To create a table with the objects stored in the S3 bucket, the following code can be used:
  create or replace table MyObjectsInS3@inmemorystorage
  from   table(aws_s3.list_objects(l_client, 'bucket-name'))
SQL-only Get List of Objects in Bucket
Although receiving and memorizing the S3 client configuration in a variable improves performance, it is also possible to use a SQL-only solution as in:
select name
,      creation_date
from   table
       ( aws_s3.list_buckets
         ( aws_s3.configure
Update March 2025
Starting release 24.0.628, the call to aws_s3.configure will require specification of the Service URL. Either service URL or endpoint name should be specified.
Service URL can be used for compatibility with non-US based S3 storage providers due to changes related to Invantive strengthens continuity: Move to European suppliers for better security and independence.
Sample of use:
  ( 'eu-central-1'
  , 'https://s3.eu-central-1.amazonaws.com'
  , 'access-key'
  , 'secret-key'
