Add Custom Objects support to SQL and Power BI driver for Freshdesk
On Freshdesk Enterprise plans only, it is possible to define custom objects, which are separate entities / tables. The Freshdesk-driver of Invantive only supports custom fields.
Custom objects are similar to tables in Odoo, or custom objects in ActiveCampaign or HubSpot.
For more information see:
https://developer.freshdesk.com/api/#custom-objects
Can support for these custom objects be added?
The entry point to retrieve them is:
https://developer.freshdesk.com/api/#retrieve_existing_custom_objects
