Connector SQL-stuurprogramma Visma.NET HRM (Talent)
Connector for Visma.NET HRM and Payroll.
Documentation on HRM Analyics Public API Swagger UI
Async gathered and returned as CSV wrapped in JSON object.
Please note separate from the regular Visma.net SQL driver for Power BI.
Talent (Visma.net HRM)
Currently there are no plans to add an Invantive SQL driver for Visma.net HRM (Talent).
The current APIs available for Visma.net HRM are asynchronous: an extract (data set) is requested and when available later fetched. There is no real-time behaviour. Also, the actual payload of the data set is in a CSV format without metadata. The CSV is embedded in JSON.
A custom development partner might better be able to suit your specific needs. The decision can be reconsidered for Visma.net HRM APIs when a more real-time API implementation with metadata becomes available.
For custom development, the HTTP packages of Invantive PSQL or HttpDownload@DataDictionary could be useful.
The preview of the currently available API is documented at HRM Analyics Public API Swagger UI.
You can execute for this as follows at Visma:
  • Register account at https://oauth.developers.visma.com/
  • Include your company details.
  • In “My Applications”, create a new “Service” application with JWT enabled.
  • Publish the application.
  • Create an integration to “HRM Analytics Public API”, and request the needed scopes.
  • Within approximately 2 days the request will be processed.
  • The access data is provided by mail.
Visma.net Financials
Visma.net HRM is a different product from Visma.net Financials; an accounting package.
The driver for Visma.net Financials is available from Invantive through:
