Fout itgenlic402 bij poging om verbinding te maken vanuit Excel-invoegtoepassing
Hello, I previously defined some Excel links which were working fine. Now, however, I am receiving these error messages below. We already have a subscription:
itgenlic402
Invantive Control for Excel can not be used due to the previously shown message.
Warning itgenlic402:
This data container has been uesd in a trial that started 156 days ago.
Please switch to a non-trial subscription within 6 months after first use.
This is currently a warning only.
Connection to this data container will no longer be possible starting 07-05-2026.
itgenuty726
A connection to the database … could not be established as user …
Provide value on ‘System.Windows.Markup.StaticResourceHolder’ threw an exception.
The method or operation is not implemented.
I tried again, and now also get this message:
itgeneor823
The OAuth access token for Exact Online has expired or is currently not accepted.
The access token has expired.
(401) Unauthorized.
Please check that Exact Online is online.
Try again later when Exact Online is offline.
Re-authenticate on Exact Online when online and the access token is still not accepted.
https://start.exactonline.nl/api/v1/current/Me
Can someone advise what I should do?
It is recommended to click on the hyperlink in the first error window directly below “Related forums topics:”. This will lead to the topic:
The next step is to replace the trial license key by the license key for your company. The related topic explains how to do this.
