Error itgenrst007: costcenterdescription1 van tabel 'REVENUETRANSACTIONS'
The custom report on Exact Online subscriptions gives an error
The following error pops up:
itgenrst007
De metadata van de kolommen ‘costcenterdescription1’ van tabel ‘REVENUETRANSACTIONS’ geven aan dat null-waardes niet mogen voorkomen, maar er is een null-waarde in rij #466.
Verzoek: Zorg ervoor dat de nullable-eigenschap in de metagegevens overeenkomt met de waarden.
This is only happening in one Exact Online company.
Can please help us out, we need this report.
The error code itgenrst007 signals that a required field has no data.
The custom report has been reviewed and modernized, but no relevant cause was found. It is recommended to provide delegation as described on Access via delegation on Invantive Cloud for consultants. The problem occurs only on one legal entity and very probably some data is corrupt or incorrect, like a required field consisting solely a special whitespace character.
The email address to which delegation should be granted is sent through a separate channel.
