Dear Invantive,
few remarks on the swift-MT940 driver (in my case bank file provided by ABN AMRO)
I’m running QueryTool 20.0.66
- some extracted fields from the driver are sometime mistaken, when the data contains the
/char;
the/will escape the extraction thus miss the content after - some few sequences are not extracted at all, not being recognized by the driver. I have not been able to find why.
I wrote this regex correction in order to have a better match.
I can provide some example files if Invantive would like to dig into this.
Regards
select
Filename
,FileLineNumber
,StatementLineNumber
,StatementAccountIdentification
,ValueDate
,Amount
--,EndToEndReference
,regexp_substr(InformationToAccountOwner,'(?<=\/EREF\/)(.*)($)') AS EndToEndReference
,ReferenceAccountOwner
--,RemittanceInformation
,CASE
WHEN regexp_substr(InformationToAccountOwner,'(?<=\/REMI\/)(.*)(?=\/EREF)|$') like '%' -- is not null
THEN regexp_substr(InformationToAccountOwner,'(?<=\/REMI\/)(.*)(?=\/EREF)|$')
ELSE Unparseable
END
AS RemittanceInformation
--,CounterPartyIdName
,CASE
WHEN regexp_substr(InformationToAccountOwner,'(?<=\/NAME\/)(.*?)((?=\/REMI)|(?=\/EREF))') is not null
THEN regexp_substr(InformationToAccountOwner,'(?<=\/NAME\/)(.*?)((?=\/REMI)|(?=\/EREF))')
ELSE CounterPartyIdName
END
AS Name
--,CounterPartyIdAccountNumber
,CASE
WHEN regexp_substr(InformationToAccountOwner,'(?<=\/IBAN\/)(.*)(?=\/BIC)') is not null
THEN regexp_substr(InformationToAccountOwner,'(?<=\/IBAN\/)(.*)(?=\/BIC)')
ELSE CounterPartyIdAccountNumber
END
AS Sender_IBAN
,Unparseable
,InformationToAccountOwner
from BankStatementLines@Bankfiles
