I am encountering an issue while attempting to retrieve the mapping table and the associated general ledger accounts. Specifically, I am using the tables: Twinfield.Views.GeneralLedgerAccountMappings@tfd and Twinfield.Views.GeneralLedgerAccountMappingAccounts@tfd respectively.
I am filtering based on a single hierarchy_code.
When retrieving the mapping (Twinfield.Views.GeneralLedgerAccountMappings@tfd), I receive 365 rows, representing the complete reporting structure.
However, when attempting to retrieve the underlying general ledger accounts (Twinfield.Views.GeneralLedgerAccountMappingAccounts@tfd), I do not get any rows returned.
It seems like that the GeneralLedgerAccountMappingAccounts views only returns the General Ledger Accounts for the first CompanyCode where I have access to and when I filter the specific hierarcy that I’am looking for, no data is found, while in the GeneralLedgerAccountMappingAccounts there is.
Please also perform the second check listed in the previous reply (the query).
Check 2
The view GeneralLedgerAccountMappingAccounts is defined in basis as:
select hry.* prefix with 'hierarchy_' label prefix with '{res:itgen_hierarchy} '
, spn.code COMPANY_CODE
from Hierarchies hry
join SystemPartitions@datadictionary spn
on spn.is_selected = true
This should select all currently selected Twinfield companies, where for each hierarchy code and company code the list of mappings is retrieved in another step.
Please execute this query in the UniversalSQL editor and check whether the expected company codes are listed as the last column.
