Itgenisr006: probleem met synchroniseren & except?
Having the following SQL-statement:
synchronize eol_count@inmemorystorage
to          timestamp_table@inmemorystorage
with update all except $rowid
identified by Division;
raises:
itgenisr006:
It is not allowed to update the primary key column on in-memory table ‘TIMESTAMP_TABLE’.
The only primary key column is $rowid, and should be excepted.
This has been running for months.
Since recent upgrade to QueryTool 24.0.389 it seems the update all except $rowid might be broken?
the full script is here sharing-an-incremental-script-for-sync-between-exact-online-and-sql-server
Is it possible to make a smaller reproduction scenario like for instance this one?
create or replace table src@inmemorystorage
select rge.value Division
,      random() Something
from   range@DataDictionary(10) rge
create or replace table dst@inmemorystorage
from   range@DataDictionary(5) rge
synchronize src@inmemorystorage
to          dst@inmemorystorage
This script does not raise an error on 24.0.392.
This does not raise error on 24.0.389.
but more interesting :
with update all
doe not raise error neither.
The same issue appears on the newly released Invantive Data Hub net8.0 24.0.445.
My previous (working) version was Invantive Data Hub net8.0 24.0.109
Some deviation has been introduced in between ?
The scripts in the linked topic have been puzzled together, and dummy tables were created out of them to factor out Exact Online. This is the script used:
create or replace table timestamp_table@inmemorystorage
( sql_lastTimestamp      int64
, sql_count              int
, eol_count              int
, eol_lastTimestamp      int64
, insertupdate           int
, to_insert              int
, to_update              int
, deleted                int
, to_delete              int
, to_modify              int
, division               int
, count_records_deleted  int
, count_records_inserted int
insert
into   timestamp_table@inmemorystorage
( sql_lastTimestamp
, sql_count
, eol_count
, eol_lastTimestamp
, insertupdate
, to_insert
, to_update
, deleted
, to_delete
, to_modify
, division
values
( 1234
, 100
, 200
, 1235
, 1
, 2
, 3
, 4
, 5
, 6
, 1234
, 8
, 9
create or replace table eol_count@inmemorystorage
select 1234 division
,      5678 eol_count
from   dual@datadictionary
identified
by          division
This indeed reproduced the itgenisr006 error as you indicated.
Upon further inspection, a typo was found in the column name in the except clause. The primary key column name of in-memory tables is rowid$, not $rowid as in the script. Changing the name in the except resolves the error.
We will investigate if we can improve the error message given that sync supports both uni-directional and bi-directional synchronization, so the column name specified in the except might not be found on both ends.
thanks !
raising an error message if column is not found in one or both end might be usefull for helping young Padawans not to make such typos errors
