The synchronize statement works indeed very well with insert, removing the technical identity column rowid$ from the insert logic.
But unless if I’m wrong I’m having difficulties with synchronizing from an @inmemorystorage table into an @sql container with an insert or update clause.
Invantive Query Tool reports the error:
itgenclr039:
One or more errors occurred.
Impossible to update identity column ‘rowid$’.
The question is not completely clear yet on how to reproduce the problem, but maybe you are referring to the need to exclude the column rowid$ with identity-generated values from the update-statement fired by the Invantive synchronize-statement.
This can be done by adding except to the update-clause as in for instance:
synchronize target@targetdc
from source@inmemorystorage
with insert
or
update all except created_by, created_at, date_created, session_created, uid
ignore changes to modified_by, modified_at, date_modified, session_modified, created_by, created_at, date_created, session_created, uid
identified
by column1
, column2
In this sample, the update does not consider a row changed when only changes are found in the listed columns:
modified_by
modified_at
date_modified
session_modified
created_by
created_at
date_created
session_created
uid
It also only tries to update the row for columns not in the list of:
created_by
created_at
date_created
session_created
uid
Effectively this can be used to provide both create and modification audit-information on initial insert, and only modification audit-information on subsequent updates.
The uid column is some kind of unique value, so might resemble your need with rowid$.
