Itgenlic825 error bij opstarten Invantive Control
Bij het opstarten van Invantive Control for Excel krijg ik eerst de foutmelding:
itgenlic825
Invantive Control for Excel kan niet gebruikt worden vanwege het eerder getoonde bericht.
Warning itgenlic825: At least one invoice is overdue. Your payment holidays ends on 05-06-2025. (123006).
Vervolgens treedt een andere foutmelding op:
itgenclr107
Provide value on ‘System.Windows.Markup.StaticResourceHolder’ threw an exception.
The method or operation is not implemented.
Er is een onbekende fout opgetreden.
met call stack:
System.NotImplementedException
System.Windows.Markup.XamlParseException
at System.Windows.Baml2006.Baml2006SchemaContext.ResolveBamlType(BamlType bamlType, Int16 typeId)
at System.Windows.Baml2006.Baml2006SchemaContext.GetXamlType(Int16 typeId)
at System.Windows.Baml2006.Baml2006Reader.Process_ElementStart()
at System.Windows.Baml2006.Baml2006Reader.ReadObject(KeyRecord record)
at System.Windows.ResourceDictionary.CreateObject(KeyRecord key)
at System.Windows.ResourceDictionary.OnGettingValue(Object key, Object& value, Boolean& canCache)
at System.Windows.ResourceDictionary.OnGettingValuePrivate(Object key, Object& value, Boolean& canCache)
at System.Windows.ResourceDictionary.GetValueWithoutLock(Object key, Boolean& canCache)
at System.Windows.ResourceDictionary.GetValue(Object key, Boolean& canCache)
at System.Windows.DeferredResourceReference.GetValue(BaseValueSourceInternal valueSource)
at System.Windows.StaticResourceExtension.TryProvideValueImpl(IServiceProvider serviceProvider, Boolean allowDeferredReference, Boolean mustReturnDeferredResourceReference)
at System.Windows.StaticResourceExtension.ProvideValueInternal(IServiceProvider serviceProvider, Boolean allowDeferredReference)
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CallProvideValue(MarkupExtension me, IServiceProvider serviceProvider)
Hoe kan ik toch Invantive Control for Excel gebruiken?
Variant is InvokeReportUserMessagesOnUIThread.
Eigenschappen zijn:
  • System.Windows.Markup.XamlParseException-Source=‘PresentationFramework’
  • System.NotImplementedException-HResult=‘-2147467263’
  • System.NotImplementedException-Source=‘PresentationFramework’
Advies is om nogmaals te proberen.
Treedt dit probleem nog op?
