Itgenlic922 / itgenlic944 foutmelding in Invantive Data Hub
11:40:04.550 itgenlic922: Ongespecificeerde fout itgenlic944.
11:40:06.552 Invantive.Basics.InvantiveLicenseException
   bij Invantive.Basics.ValidationException..ctor(GlobalState owner, ExecutionOptions executionOptions, String messageCode, String errorMessage, String kindRequest, String localStackTrace, String nk, Exception innerException, Boolean inheritMessageCodeWhenPresent, Nullable`1 uid, Nullable`1 isRecoverable, String poolIdentityId, String url, Nullable`1 partyUid, String partitionCode, String tableName, String parameter1, String parameter2, String parameter3, String parameter4, String parameter5, String clientId)
   bij Invantive.Basics.InvantiveLicenseException..ctor(GlobalState owner, ExecutionOptions executionOptions, String errorCode, String errorMessage, String kindRequest, String stackTrace, Ex...re.SetCurrent(GlobalState owner, ExecutionOptions executionOptions, UtilityBaseCore value)
   bij Invantive.Producer.Data.Hub.Utility.GetCurrent(GlobalState owner, ExecutionOptions executionOptions)
   bij Invantive.Producer.Data.Hub.QueryEngine.Run(GlobalState owner, ExecutionOptions executionOptions, String[] arguments)
   bij Invantive.Producer.Data.Hub.Program.Main(String[] args)
   bij Invantive.Basics.LicenseUtility.CheckNewLicense(GlobalState owner, ExecutionOptions executionOptions, IBasicProviderManager manager, String licenseKey, String prolongationKey, Boolean forceValidation, String fileNameOrigin)
   bij Invantive.Producer.LicenseHelper.CheckLicense(GlobalState owner, ExecutionOptions executionOptions, Boolean forceValidation)
**** 11:40:06.624 Fout itgenuty690: Er is een licentieprobleem opgetreden bij het uitvoeren in headless modus. Start de applicatie opnieuw in interactieve modus om het probleem op te lossen. Interactieve modus is de standaardmodus, tenzij de opdrachtregelparameter 'i' of de lange variant 'interactive' is ingesteld op false, zoals in het aanroepende batchbestand.
itgenlic252: De applicatie 'Invantive Data Hub Multi-Platform' zal worden afgesloten. Er ontbreekt een geldige licentiecode of de licentieovereenkomst is niet geaccepteerd.
De oorzaak van dit probleem is niet bekend.
Gelieve een upgrade te plaatsen naar 26.0.213 en het probleem nogmaals op te wekken. Dit verzamelt extra diagnostische informatie binnen het scherm Systeemberichten op Invantive Cloud:
https://download.invantive.com/release/msi/Invantive%20Data%20Hub-win-x64-net10.0-26.0.213.zip
Ik heb de upgrade gedaan en de “kopieer.bat” nogmaals gedraaid en de foutmelding is er (uiteraard) nog steeds.
Dank voor het draaien!
De oorzaak is naar verwachting gevonden: in de keten van licentieverlengingen werd ergens in het proces na een foutmelding verzuimd om een veld leeg te maken. Dit is opgelost.
De oplossing is opnieuw starten van Data Hub, maar dan in interactieve modus. U dient eenmalig uw licentiesleutel opnieuw in te voeren.
U kunt ook de licentiesleutel hard meegeven via /licensekey zoals beschreven in:
