De volgende foutmelding treedt op bij het aanmelden op Exact Online:
itgenobr267
A connection to the database ACME\EOL could not be established.
Could not extract Azure AD B2C form action.
Het probleem treedt niet op met Exact Online via het Invantive Query Tool.
Volledige log:
2024-11-22 10:09:13.493 Information itgencmr456: Connecting to Exact Online (alias eol).
2024-11-22 10:09:16.271 Error itgencun016: Error itgenobr267: A connection to the database ACME\EOL could not be established.
2024-11-22 10:09:18.287 Error itgenobr267: Invantive.Basics.InvantiveSqlException
ValidationException
at Invantive.Basics.ValidationException..ctor(GlobalState owner, ExecutionOptions executionOptions, String messageCode, String errorMessage, String kindRequest, String localStackTrace, String nk, Exception innerException, Boolean inheritMessageCodeWhenPresent, Nullable`1 uid, Boolean isRecoverable, String poolIdentityId, String url)
at Invantive.Basics.InvantiveSqlException..ctor(GlobalState owner, ExecutionOptions executionOptions, String validationCode, String errorMessage, String kindRequest, String stackTrace, String nk, Exception innerException, Boolean inheritMessageCodeWhenPresent, Nullable`1 uid, Boolean isRecoverable, String poolIdentityId)
at Invantive.Data.OAuth.OAuthBackgroundProvider.GetOAuthAccessTokenForEOL(GlobalState owner, ExecutionOptions executionOptions, String providerName, OAuthInformation oauthInfo, Credentials credentials)
at Invantive.Data.OAuth.OAuthBackgroundProvider.Invantive.Data.IOAuthProvider.GetOAuthToken(GlobalState owner, ExecutionOptions executionOptions, SerializableDatabase database, DataContainer dataContainer, OAuthInformation oauthInfo, Credentials credentials)
at Invantive.Data.ConnectionManager.A(GlobalState , ExecutionOptions executionOptions, SerializableDatabase , DataContainer , OAuthInformation , Credentials )
at Invantive.Data.ConnectionManager.a(GlobalState , ExecutionOptions executionOptions, SerializableDatabase , DataContainer , OAuthInformation , Credentials )
at Invantive.Data.ConnectionManager.GetOAuthTokenForConnection(GlobalState owner, ExecutionOptions executionOptions, SerializableDatabase database, DataContainer dataContainer, ISupportsOAuth provider, Credentials credentials, Boolean ignoreDecryptionErrors, Boolean& decryptionErrorsOccurred)
at Invantive.Data.ConnectionManager.A(GlobalState , ExecutionOptions executionOptions, IConnectionDataProvider , SerializableDatabase , DataContainer , Credentials credentials, Boolean , Boolean& )
at Invantive.Data.ConnectionManager.OpenDataContainerProvider(GlobalState owner, ExecutionOptions executionOptions, SerializableDatabase database, DataContainer dataContainer, Credentials credentials, List`1 triedProviders, Boolean ignoreDecryptionErrors, Boolean& decryptionErrorsOccurred)
at Invantive.Data.ConnectionManager.A(GlobalState , ExecutionOptions executionOptions, CredentialsContainer , Boolean , Boolean& )
at Invantive.Producer.UtilityBaseCore.CheckConnection(GlobalState owner, ExecutionOptions executionOptions, Boolean forceReconnect, Boolean silent, String databaseName, CredentialsContainer credentialsContainer)
at Invantive.Producer.Data.Hub.QueryEngine.Run(String[] arguments)
at Invantive.Producer.Data.Hub.Program.Main(String[] args)
2024-11-22 10:09:18.304 Question: Question: Do you want to discover available databases? Discovery might find new databases.
The last discovery was run on 15/12/2023 12:07:36.
2024-11-22 10:09:18.304 Information itgencun003: Return default decision: Yes.
2024-11-22 10:09:18.315 Error itgencun016: Error itgendhb005: Could not connect to database 'ACME\EOL'. Application will be closed.
2024-11-22 10:09:18.318 Error itgendhb005: ValidationException
at Invantive.Producer.Data.Hub.QueryEngine.Run(String[] arguments) in c:\smoke\ws-22.0\Invantive.Data.Hub\src\Invantive.Producer.Data.Hub\QueryEngine.cs:line 631
2024-11-22 10:09:18.325 Error itgenube182: itgendhb005: Could not connect to database 'ACME\EOL'. Application will be closed.
