I have an issue with UINT datatype in a script replicating one-way from MySQL to SQL Server.
My MySql source as an ID int(10) unsigned NOT NULL AUTO_INCREMENT
The source MySQL container is seen by Query Tool as INT
I first execute:
create or replace table tbllog@sqlserver as select * from tbllog@mysql LIMIT 10
to create my table in SQL Server with few records.
The resulting datatype of ID in SQL Server becomes: numeric(10,0)
After this I try to execute:
BULK INSERT into tbllog@sqlserver
( ID
, BeginVerbruik
, EindVerbruik
, GastID
, LocatieID
, KaartNummer
, Result
, BeginDatumTijd
, EindDatumTijd
select ID
, BeginVerbruik
, EindVerbruik
, GastID
, LocatieID
, KaartNummer
, Result
, BeginDatumTijd
, EindDatumTijd
from tbllog@mysqlserver
where ID BETWEEN 698 AND 100000
I get an itgenrst004 error on the datatype:
itgenrst004
The type of the actual data must match the data type of the column ‘id’ in ‘’.
Ensure that the actual data data type (currently ‘UInt32’) in row #1 is cast to the data type (currently ‘decimal’).
id (UInt32/decimal): 698, beginverbruik (Int32/int32): 0, eind…/int32): 0, locatieid (Int32/int32): 0, result (Int32/int32): 0
We see that now Query Tool sees the ID as:
- MySQL: UInt32
- SQL Server: decimal (data type created by the
create or replacestatement)
Indeed the Uint32 data type does not exists in SQL Server. But Create or Replace statement is able to overcome this whereas the BULK INSERT not.
In my edge case, I can’t use the CREATE OR REPLACE Statement (nor SYNCHRONIZE) because the dataset is too big on the source and I need to implement a home made script that will truncate in small batches the data.
thanks for your help
Ref:
- MySQL creation script here
