Itgensdf031 Could not find the connector for connection with alias 'ic'
Sinds ik overgestapt ben van 20.0 naar 20.1 krijg ik de volgende foutmelding bij synchronisatie van een bestaand Excel rekenmodel:
itgensdf031: Kan velden van blok 'P&L (P&L)' niet verversen.
Could not find the connector for connection with alias 'ic'.
Bericht ID: dc4ebdf1-b2b7-4e28-82f9-5296a38a283f
Opgetreden (UTC): 26-3-2021 13:51:09
select BL.PERIODS_YEAR_YEARS_BALANCE_CODE_ATTR label 'GrootboekCode'                                                       --A
,      cll.ReportClass4        --X
from   ExactOnlineXML..BalanceLinesPerPeriod bl
left
outer
join   ExactOnlineXML..GLAccountClassifications gcm
on     gcm.division_code = bl.division_code
and    gcm.GLCLASSIFICATIONLINKS_GLACCOUNT_CODE_ATTR = BL.Periods_Year_Years_Balance_Code_ATTR
left
outer
join   ExactOnlineREST..GLAccounts gla1
on     gla1.division = bl.division_code
and    gla1.CODE = BL.PERIODS_YEAR_YEARS_BALANCE_CODE_ATTR
left
outer
join   ExactOnlineREST..Budgets bud
on     bud.division = bl.division_code
and    bud.GLAccountCode = BL.PERIODS_YEAR_YEARS_BALANCE_CODE_ATTR
and    bud.ReportingYear = BL.PERIODS_YEAR_REPORTINGYEAR_ATTR
and    bud.ReportingPeriod = BL.ReportingPeriod_ATTR
and    (:P_BUDGETSCENARIO is null or bud.BudgetScenarioCode = :P_BUDGETSCENARIO)     --THIS ONE
join   systemdivisions sdn
on     sdn.code = to_number(bl.division_code)
left
outer
join   CURRENCY@ic CUR
on     CUR.Currency = sdn.currency
left
outer
join   ( select trim(cast(cll.classificationcode as varchar2)) classificationcode, cll.reportclass1, cll.reportclass2, cll.reportclass3, cll.reportclass4 from CLASSLINKS@ic CLL ) cll
on     CLL.ClassificationCode = GCM.GLCLASSIFICATION_CODE_ATTR
--where  bl.division_code = coalesce(to_char(:ex0), bl.division_code)
--where  GLA1.BalanceType = 'B'
where  BL.PERIODS_YEAR_REPORTINGYEAR_ATTR >= :P_YEAR_FROM
and    BL.PERIODS_YEAR_REPORTINGYEAR_ATTR <= :P_YEAR_TO
and    BL.ReportingPeriod_ATTR >= :P_PERIOD_FROM
and    BL.ReportingPeriod_ATTR <= :P_PERIOD_TO
--and    (:P_BUDGETSCENARIO is null or bud.BudgetScenarioCode = :P_BUDGETSCENARIO)
union
all
ValidationException
ValidationException
   bij Invantive.Basics.ValidationException..ctor(GlobalState owner, ExecutionOptions executionOptions, String messageCode, String messageText, String kindRequest, String localStackTrace, String nk, Exception innerException, Boolean inheritMessageCodeWhenPresent, Nullable`1 uid, Boolean isRecoverable, String poolIdentityId)
   bij Invantive.Data.ConnectionManager.GetActiveProviderByConnectionAlias(GlobalState owner, ExecutionOptions executionOptions, String alias, Boolean failWhenNotFound)
   bij Invantive.Sql.V1.DataSourceOrFunctionTree.OnPrepare(GlobalState owner, ExecutionOptions executionOptions, TableOrFunctionSpecContext input)
   bij ISQL.ZZ`1.OnPrepare(GlobalState owner, ExecutionOptions executionOptions, IParseTree context)
   bij Invantive.Sql.V1.QueryTree.Prepare(GlobalState owner, ExecutionOptions executionOptions, IParseTree parseTree)
   bij Invantive.Sql.V1.QueryTree.CreateFrom(GlobalState owner, ExecutionOptions executionOptions, IProviderManager manager, IParseTree parseTree, ExecutionEnvironment executionEnvironment, IQ queryPlanState)
   bij Invantive.Sql.V1.SelectStatementTree.VisitDataSource(GlobalState owner, ExecutionOptions executionOptions, DataSourceContext context)
   bij Invantive.Sql.V1.SelectStatementTree.VisitJoinStatement(JoinStatementContext context)
   bij Invantive.Sql.InvantiveSQL.JoinStatementContext.Accept[TResult](IParseTreeVisitor`1 visitor)
   bij Antlr4.Runtime.Tree.AbstractParseTreeVisitor`1.VisitChildren(IRuleNode node)
   bij Invantive.Sql.InvantiveSQLBaseVisitor`1.VisitJoinStatements(JoinStatementsContext context)
   bij Invantive.Sql.V1.SelectStatementTree.VisitJoinStatements(JoinStatementsContext context)
   bij Invantive.Sql.V1.SelectStatementTree.ExtractSelectStatement(GlobalState owner, ExecutionOptions executionOptions, UniqueSelectStatementContext context, CombineMethod combineMethod, AliasedColumn[] distinctOnColumns)
   bij Invantive.Sql.V1.SelectStatementTree.OnPrepare(GlobalState owner, ExecutionOptions executionOptions, SelectStatementContext context)
   bij Invantive.Sql.V1.SqlEngine.OJ(GlobalState , ExecutionOptions , IProviderManager , ParameterList , ExecutionEnvironment , IParseTree , IQ )
   bij Invantive.Sql.V1.SqlEngine.HZ.M(IParseTree )
   bij System.Linq.Enumerable.WhereSelectArrayIterator`2.MoveNext()
   bij System.Linq.Buffer`1..ctor(IEnumerable`1 source)
   bij System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source)
   bij Invantive.Sql.V1.SqlEngine.Execute(GlobalState owner, ExecutionOptions executionOptions, IProviderManager manager, String sqlStatement, ParameterList parameters, Boolean allowSelect, ExecutionEnvironment executionEnvironment, IQ queryPlanState)
   bij Invantive.Sql.V1.SqlEngine.Parse(GlobalState owner, ExecutionOptions executionOptions, IProviderManager manager, String sqlStatement, ParameterList parameters, Boolean allowSelect, ExecutionEnvironment executionEnvironment, IQ queryPlanState)
   bij Invantive.Data.ConnectionManager.HV(GlobalState , ExecutionOptions , String , String , ParameterList )
   bij Invantive.Data.ConnectionManager.GetQueryMetadata(GlobalState owner, ExecutionOptions executionOptions, String baseObject, String actionSql, ParameterList parameters)
   bij Invantive.Producer.Control.Utility.ConstructSql(GlobalState owner, ExecutionOptions executionOptions, ModelCache modelCache, iea_blocks_v block, ParameterList& parameterList, Dictionary`2& originalSelectFields, Dictionary`2& additionalSelectFields, Boolean addAdditionalSelectFields, Boolean formatStatement, String replaceWhere, Boolean allowLoadFromCache, Boolean outputFields)
   bij Invantive.Producer.Control.Utility.RefreshFields(GlobalState owner, ExecutionOptions executionOptions, ModelCache modelCache, iea_blocks_v block, Boolean allowLoadFromCache)
   bij Invantive.Producer.Control.SyncToDatabaseForm.syncBackGroundWorker_DoWork(Object sender, DoWorkEventArgs e)
   bij System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
   bij System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
   bij System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
   bij System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink)
   bij System.Runtime.Remoting.Proxies.AgileAsyncWorkerItem.DoAsyncCall()
   bij System.Runtime.Remoting.Proxies.AgileAsyncWorkerItem.ThreadPoolCallBack(Object o)
   bij System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(Object state)
   bij System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   bij System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   bij System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
   bij System.Threading.ThreadPoolWorkQueue.Dispatch()
   bij System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
--- Einde van stacktracering vanaf vorige locatie waar uitzondering is opgetreden ---
   bij System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   bij Invantive.Producer.Control.Utility.ConstructSql(GlobalState owner, ExecutionOptions executionOptions, ModelCache modelCache, iea_blocks_v block, ParameterList& parameterList, Dictionary`2& originalSelectFields, Dictionary`2& additionalSelectFields, Boolean addAdditionalSelectFields, Boolean formatStatement, String replaceWhere, Boolean allowLoadFromCache, Boolean outputFields) in C:\Users\gle3.WS212\Documents\ws-master\Invantive.Control\src\Invantive.Producer.Control\Utility.cs:regel 6519
   bij Invantive.Producer.Control.Utility.RefreshFields(GlobalState owner, ExecutionOptions executionOptions, ModelCache modelCache, iea_blocks_v block, Boolean allowLoadFromCache) in C:\Users\gle3.WS212\Documents\ws-master\Invantive.Control\src\Invantive.Producer.Control\Utility.cs:regel 6862
   bij Invantive.Producer.Control.SyncToDatabaseForm.syncBackGroundWorker_DoWork(Object sender, DoWorkEventArgs e) in C:\Users\gle3.WS212\Documents\ws-master\Invantive.Control\src\Invantive.Producer.Control\ThisAddIn.cs:regel 816
Hoe krijg ik het model weer werkend op 20.1?
De ingebouwde connector ic van Invantive Control is hernoemd in 20.1 naar InvantiveControl.
Vervang alle voorkomens van @ic door @InvantiveControl.
De volgende 20.1 release zal een duidelijker hint geven wat de nieuwe naam is.
Algemene informatie over de foutcode itgensdf031 is te vinden op Itgensdf031 Kan velden van blok 'Transactieregel (tle) niet verversen.
