Sinds ik de nieuwe update 22.0.341 heb geïnstalleerd werkt mijn excel-sheet niet meer.
Hoe kan ik dit oplossen? (NB … ik ben zelf niet handig met programmeren in sql
Ik krijg de volgende melding:
itgensdf031: Kan velden van blok 'Project (PROJECT)' niet verversen.
Onbekende tabel 'PROJECTS'. Mogelijke geldige alternatieven: Projects, ExactOnlineREST.Project.CostEntryRecentProjects, ExactOnlineREST.Sync.SyncProjects.
Bericht ID: 25e9771f-2174-4cf9-92c0-6fe24275ac6b
Opgetreden (UTC): 20-9-2022 08:58:15
SELECT p.Code ProjectCode
, p.Description ProjectDescription
, p.AccountName
, c.Code ClassificationCode
, p.ClassificationDescription
, p.TypeDescription
, p.BudgetedAmount ProjectBudgetedAmount
, sil.AmountDC SalesInvoiceAmountDC
, p.BudgetedRevenue ProjectBudgetedRevenue
, p.BudgetedCosts ProjectBudgetedCosts
, tle.AmountDC TransactionLineAmountDC
, p.SalesTimeQuantity SalesTimeQuantity
, ptt.Quantity HourQuantity
FROM ExactOnlineREST.Projects p
LEFT
OUTER
JOIN sle@inmemorystorage sil
ON sil.Project = p.ID
LEFT
OUTER
JOIN ( select tle.Project
, sum(tle.AmountDC) AmountDC
from tle@inmemorystorage tle
group
by tle.Project
) tle
ON tle.Project = p.ID
LEFT
OUTER
JOIN ( SELECT ptn.Project
, SUM(ptn.Quantity) Quantity
FROM ExactOnlineREST..PjtTimeTransactions ptn
WHERE ptn.HourStatus = 20
and 1 = 0 /* No longer used. */
GROUP
BY ptn.Project
) ptt
ON ptt.Project = p.ID
LEFT
OUTER
JOIN act@inmemorystorage a
ON a.Id = p.Account
LEFT
OUTER
JOIN ExactOnlineREST..AccountClassifications c
ON c.ID = a.Classification2
WHERE p.EndDate IS NULL
ORDER
BY p.Code
ValidationException
ValidationException
bij Invantive.Basics.ValidationException..ctor(GlobalState owner, ExecutionOptions executionOptions, String messageCode, String errorMessage, String kindRequest, String localStackTrace, String nk, Exception innerException, Boolean inheritMessageCodeWhenPresent, Nullable`1 uid, Boolean isRecoverable, String poolIdentityId, String url)
bij Invantive.Data.DataContainerMetadata.ThrowErrorForUnknownTable(GlobalState owner, ExecutionOptions executionOptions, IProviderManager manager, String fullyQualifiedName)
bij Invantive.Data.GenericProvider.ThrowErrorForUnknownTable(GlobalState owner, ExecutionOptions executionOptions, String fullyQualifiedName)
bij Invantive.Data.Providers.ExactOnline.ExactOnlineProvider.ThrowErrorForUnknownTable(GlobalState owner, ExecutionOptions executionOptions, String fullyQualifiedName)
bij Invantive.Sql.V1.DataSourceOrFunctionTree.OnExecute(GlobalState owner, ExecutionOptions executionOptions, ParameterList parameters, ExpressionParser expressionParser)
bij Invantive.Sql.V1.QueryTree.Execute(GlobalState owner, ExecutionOptions executionOptions, ParameterList parameters, ExpressionParser expressionParser)
bij Invantive.Sql.V1.SelectStatementTree.OnExecute(GlobalState owner, ExecutionOptions executionOptions, ParameterList parameters, ExpressionParser expressionParser)
bij Invantive.Sql.V1.QueryPlan.ForcePlan(GlobalState owner, ExecutionOptions executionOptions)
bij Invantive.Sql.V1.QueryPlan.GetFields(GlobalState owner, ExecutionOptions executionOptions)
bij Invantive.Data.ConnectionManager.YY(GlobalState , ExecutionOptions , String , String , ParameterList )
bij Invantive.Data.ConnectionManager.GetQueryMetadata(GlobalState owner, ExecutionOptions executionOptions, String baseObject, String actionSql, ParameterList parameters)
bij Invantive.Producer.Control.Utility.ConstructSql(GlobalState owner, ExecutionOptions executionOptions, ModelCache modelCache, iea_blocks_v block, ParameterList& parameterList, Dictionary`2& originalSelectFields, Dictionary`2& additionalSelectFields, Boolean addAdditionalSelectFields, Boolean formatStatement, String replaceWhere, Boolean allowLoadFromCache, Boolean outputFields)
bij Invantive.Producer.Control.Utility.RefreshFields(GlobalState owner, ExecutionOptions executionOptions, ModelCache modelCache, iea_blocks_v block, Boolean allowLoadFromCache)
bij Invantive.Producer.Control.SyncToDatabaseForm.syncBackGroundWorker_DoWork(Object sender, DoWorkEventArgs e)
bij System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
bij System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
bij System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
bij System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink)
bij System.Runtime.Remoting.Proxies.AgileAsyncWorkerItem.DoAsyncCall()
bij System.Runtime.Remoting.Proxies.AgileAsyncWorkerItem.ThreadPoolCallBack(Object o)
bij System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(Object state)
bij System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
bij System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
bij System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
bij System.Threading.ThreadPoolWorkQueue.Dispatch()
bij System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
--- Einde van stacktracering vanaf vorige locatie waar uitzondering is opgetreden ---
bij System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
bij Invantive.Producer.Control.Utility.ConstructSql(GlobalState owner, ExecutionOptions executionOptions, ModelCache modelCache, iea_blocks_v block, ParameterList& parameterList, Dictionary`2& originalSelectFields, Dictionary`2& additionalSelectFields, Boolean addAdditionalSelectFields, Boolean formatStatement, String replaceWhere, Boolean allowLoadFromCache, Boolean outputFields) in c:\smoke\ws-22.0\Invantive.Control\src\Invantive.Producer.Control\Utility.cs:regel 6692
bij Invantive.Producer.Control.Utility.RefreshFields(GlobalState owner, ExecutionOptions executionOptions, ModelCache modelCache, iea_blocks_v block, Boolean allowLoadFromCache) in c:\smoke\ws-22.0\Invantive.Control\src\Invantive.Producer.Control\Utility.cs:regel 7035
bij Invantive.Producer.Control.SyncToDatabaseForm.syncBackGroundWorker_DoWork(Object sender, DoWorkEventArgs e) in c:\smoke\ws-22.0\Invantive.Control\src\Invantive.Producer.Control\ThisAddIn.cs:regel 814
