Zeeschuimer NDJSON omzetten naar een tabel
Een export in NDJSON-formaat vanuit de Zeeschuimer-extensie voor een browser kan omgezet worden naar een tabel met:
from   ndjsontable
       ( passing file 'c:\temp\zeeschuimer-export-twitter.com-2025-10-09T125248.ndjson'
         columns id                                                int64 path 'id'
         ,       nav_index                                         varchar2 path 'nav_index'
         ,       item_id                                           varchar2 path 'item_id'
         ,       timestamp_collected                               number path 'timestamp_collected'
         ,       source_platform                                   varchar2 path 'source_platform'
         ,       source_platform_url                               varchar2 path 'source_platform_url'
         ,       source_url                                        varchar2 path 'source_url'
         ,       user_agent                                        varchar2 path 'user_agent'
         ,       data_typename                                     varchar2 path 'data.__typename'
         ,       data_id                                           varchar2 path 'data.id'
         ,       data_views_count                                  varchar2 path 'data.views.count'
         ,       data_views_state                                  varchar2 path 'data.views.state'
         ,       data_promoted                                     boolean  path 'data.promoted'
         ,       data_rest_id                                      varchar2 path 'data.rest_id'
         ,       data_post_video_description                       varchar2 path 'data.post_video_description'
         ,       data_unmention_data_json                          varchar2 path 'data.unmention_data'
         ,       data_is_translatable                              boolean  path 'data.is_translatable'
         ,       data_source                                       varchar2 path 'data.source'
         ,       data_edit_control_edits_remaining                 int32    path 'data.edit_control.edits_remaining'
         ,       data_edit_control_is_edit_eligible                boolean  path 'data.edit_control.is_edit_eligible'
         ,       data_edit_control_editable_until_msec             varchar2 path 'data.edit_control.editable_until_msec'
         ,       data_edit_tweet_ids1                              varchar2 path 'data.edit_control.edit_tweet_ids[0]'
         ,       data_quick_promote_eligibility                    varchar2 path 'data.quick_promote_eligibility.eligibility'
         ,       data_grok_analysis_button                         boolean  path 'data.grok_analysis_button'
         ,       data_core_result_typename                         varchar2 path 'data.core.user_results.result.__typename'
         ,       data_core_result_id                               varchar2 path 'data.core.user_results.result.id'
         ,       data_core_result_rest_id                          varchar2 path 'data.core.user_results.result.rest_id'
         ,       data_core_result_affiliates_highlighted_json      varchar2 path 'data.core.user_results.result.affiliates_highlighted_label'
         ,       data_core_result_avatar_image_url                 varchar2 path 'data.core.user_results.result.avatar.image_url'
         ,       data_core_result_core_created_at_c                varchar2 path 'data.core.user_results.result.core.created_at'
         ,       data_core_result_core_name                        varchar2 path 'data.core.user_results.result.core.name'
         ,       data_core_result_core_screen_name                 varchar2 path 'data.core.user_results.result.core.screen_name'
         ,       data_core_result_dm_permissions_can_dm            boolean  path 'data.core.user_results.result.dm_permissions.can_dm'
         ,       data_core_result_dm_permissions_can_dm_on_xchat   boolean  path 'data.core.user_results.result.dm_permissions.can_dm_on_xchat'
         ,       data_core_result_has_graduated_access             boolean  path 'data.core.user_results.result.has_graduated_access'
         ,       data_core_result_is_blue_verified                 boolean  path 'data.core.user_results.result.is_blue_verified'
         ,       data_core_result_legacy_default_profile           boolean  path 'data.core.user_results.result.legacy.default_profile'
         ,       data_core_result_legacy_default_profile_image     boolean  path 'data.core.user_results.result.legacy.default_profile_image'
         ,       data_core_result_legacy_description               varchar2 path 'data.core.user_results.result.legacy.description'
         ,       data_core_result_legacy_description_url1          varchar2 path 'data.core.user_results.result.legacy.entities.description.urls[0]'
         ,       data_core_result_legacy_url1                      varchar2 path 'data.core.user_results.result.legacy.entities.url.urls[0].url'
         ,       data_core_result_legacy_display_url1              varchar2 path 'data.core.user_results.result.legacy.entities.url.urls[0].display_url'
         ,       data_core_result_legacy_expanded_url1             varchar2 path 'data.core.user_results.result.legacy.entities.url.urls[0].expanded_url'
         ,       data_core_result_legacy_fast_followers_count      int64    path 'data.core.user_results.result.legacy.fast_followers_count'
         ,       data_core_result_legacy_favourites_count          int64    path 'data.core.user_results.result.legacy.favourites_count'
         ,       data_core_result_legacy_followers_count           int64    path 'data.core.user_results.result.legacy.followers_count'
         ,       data_core_result_legacy_friends_count             int64    path 'data.core.user_results.result.legacy.friends_count'
         ,       data_core_result_legacy_custom_timelines          varchar2 path 'data.core.user_results.result.legacy.has_custom_timelines'
         ,       data_core_result_legacy_is_translator             varchar2 path 'data.core.user_results.result.legacy.is_translator'
         ,       data_core_result_legacy_listed_count              int64    path 'data.core.user_results.result.legacy.listed_count'
         ,       data_core_result_legacy_media_count               int64    path 'data.core.user_results.result.legacy.media_count'
         ,       data_core_result_legacy_normal_followers_count    int64    path 'data.core.user_results.result.legacy.normal_followers_count'
         ,       data_core_result_legacy_possibly_sensitive        varchar2 path 'data.core.user_results.result.legacy.possibly_sensitive'
         ,       data_core_result_legacy_profile_banner_url        varchar2 path 'data.core.user_results.result.legacy.profile_banner_url'
         ,       data_core_result_legacy_profile_interstitial_type varchar2 path 'data.core.user_results.result.legacy.profile_interstitial_type'
         ,       data_core_result_legacy_pinned_tweet_id1          int64    path 'data.core.user_results.result.legacy.pinned_tweet_ids_str[0]'
         ,       data_core_result_legacy_pinned_tweet_id2          int64    path 'data.core.user_results.result.legacy.pinned_tweet_ids_str[1]'
         ,       data_core_result_legacy_pinned_tweet_id3          int64    path 'data.core.user_results.result.legacy.pinned_tweet_ids_str[2]'
         ,       data_core_result_legacy_statuses_count            int64    path 'data.core.user_results.result.legacy.statuses_count'
         ,       data_core_result_legacy_translator_type           varchar2 path 'data.core.user_results.result.legacy.translator_type'
         ,       data_core_result_legacy_url                       varchar2 path 'data.core.user_results.result.legacy.url'
         ,       data_core_result_legacy_want_retweets             varchar2 path 'data.core.user_results.result.legacy.want_retweets'
         ,       data_core_result_legacy_withheld_country1         varchar2 path 'data.core.user_results.result.legacy.withheld_in_countries[0]'
         ,       data_core_result_legacy_withheld_country2         varchar2 path 'data.core.user_results.result.legacy.withheld_in_countries[1]'
         ,       data_core_result_legacy_withheld_country3         varchar2 path 'data.core.user_results.result.legacy.withheld_in_countries[2]'
         ,       data_core_result_location                         varchar2 path 'data.core.user_results.result.location.location'
         ,       data_core_result_can_media_tag                    varchar2 path 'data.core.user_results.result.media_permissions.can_media_tag'
         ,       data_core_result_parody_commentary_fan_label      varchar2 path 'data.core.user_results.result.parody_commentary_fan_label'
         ,       data_core_result_profile_image_shape              varchar2 path 'data.core.user_results.result.profile_image_shape'
         ,       data_core_result_privacy_protected                varchar2 path 'data.core.user_results.result.privacy.protected'
         ,       data_core_result_relationship_perspectives_fllwng varchar2 path 'data.core.user_results.result.relationship_perspectives.following'
         ,       data_core_result_tipjar_settings_json             varchar2 path 'data.core.user_results.result.tipjar_settings'
         ,       data_core_result_verified                         varchar2 path 'data.core.user_results.result.verification.verified'
         ,       data_legacy_bookmark_count                        int64    path 'data.legacy.bookmark_count'
         ,       data_legacy_bookmarked                            boolean  path 'data.legacy.bookmarked'
         ,       data_legacy_display_text_range1                   int64    path 'data.legacy.display_text_range[0]'
         ,       data_legacy_display_text_range2                   int64    path 'data.legacy.display_text_range[1]'
         ,       data_legacy_created_at                            varchar2 path 'data.legacy.created_at'
         ,       data_legacy_conversation_id_str                   varchar2 path 'data.legacy.conversation_id_str'
         ,       data_legacy_id_str                                varchar2 path 'data.legacy.id_str'
         ,       data_legacy_user_id_str                           varchar2 path 'data.legacy.user_id_str'
         ,       data_legacy_retweeted                             varchar2 path 'data.legacy.retweeted'
         ,       data_legacy_retweet_count                         int64    path 'data.legacy.retweet_count'
         ,       data_legacy_reply_count                           int64    path 'data.legacy.reply_count'
         ,       data_legacy_quote_count                           int64    path 'data.legacy.quote_count'
         ,       data_legacy_possible_sensitive_editable           varchar2 path 'data.legacy.possibly_sensitive_editable'
         ,       data_legacy_possibly_sensitive                    varchar2 path 'data.legacy.possibly_sensitive'
         ,       data_legacy_lang                                  varchar2 path 'data.legacy.lang'
         ,       data_legacy_is_quote_status                       boolean  path 'data.legacy.is_quote_status'
         ,       data_legacy_full_text                             varchar2 path 'data.legacy.full_text'
         ,       data_legacy_favorited                             varchar2 path 'data.legacy.favorited'
         ,       data_legacy_favorite_count                        int64    path 'data.legacy.favorite_count'
         ,       data_legacy_entities_hashtags_json                varchar2 path 'data.legacy.entities.hashtags'
         ,       data_legacy_entities_symbols_json                 varchar2 path 'data.legacy.entities.symbols'
         ,       data_legacy_entities_timestamps_json              varchar2 path 'data.legacy.entities.timestamps'
         ,       data_legacy_entities_urls_json                    varchar2 path 'data.legacy.entities.urls'
         ,       data_legacy_entities_mention_user1_id             varchar2 path 'data.legacy.entities.user_mentions[0].id_str'
         ,       data_legacy_entities_mention_user1_name           varchar2 path 'data.legacy.entities.user_mentions[0].name'
         ,       data_legacy_entities_mention_user1_screen_name    varchar2 path 'data.legacy.entities.user_mentions[0].screen_name'
         ,       data_legacy_entities_mention_user2_id             varchar2 path 'data.legacy.entities.user_mentions[1].id_str'
         ,       data_legacy_entities_mention_user2_name           varchar2 path 'data.legacy.entities.user_mentions[1].name'
         ,       data_legacy_entities_mention_user2_screen_name    varchar2 path 'data.legacy.entities.user_mentions[1].screen_name'
         ,       data_legacy_entities_mention_user3_id             varchar2 path 'data.legacy.entities.user_mentions[2].id_str'
         ,       data_legacy_entities_mention_user3_name           varchar2 path 'data.legacy.entities.user_mentions[2].name'
         ,       data_legacy_entities_mention_user3_screen_name    varchar2 path 'data.legacy.entities.user_mentions[2].screen_name'
         ,       data_legacy_retweet_typename                      varchar2 path 'data.legacy.retweeted_status_result.result.__typename'
         ,       data_legacy_retweet_rest_id                       varchar2 path 'data.legacy.retweeted_status_result.result.rest_id'
         ,       data_legacy_retweet_source                        varchar2 path 'data.legacy.retweeted_status_result.result.source'
         ,       data_legacy_retweet_grok_analysis_button          varchar2 path 'data.legacy.retweeted_status_result.result.grok_analysis_button'
         ,       data_legacy_retweet_is_translatable               varchar2 path 'data.legacy.retweeted_status_result.result.is_translatable'
         ,       data_legacy_retweet_views_count                   int64    path 'data.legacy.retweeted_status_result.result.views.count'
         ,       data_legacy_retweet_views_state                   varchar2 path 'data.legacy.retweeted_status_result.result.views.state'
         ,       data_legacy_retweet_note_is_expandable            varchar2 path 'data.legacy.retweeted_status_result.result.note_tweet.is_expandable'
         ,       data_legacy_retweet_note_id                               varchar2 path 'data.legacy.retweeted_status_result.result.note_tweet.note_tweet_results.result.id'
         ,       data_legacy_retweet_note_text                             varchar2 path 'data.legacy.retweeted_status_result.result.note_tweet.note_tweet_results.result.text'
         ,       data_legacy_retweet_bookmark_count                        int64    path 'data.legacy.retweeted_status_result.result.legacy.bookmark_count'
         ,       data_legacy_retweet_bookmarked                            boolean  path 'data.legacy.retweeted_status_result.result.legacy.bookmarked'
         ,       data_legacy_retweet_display_text_range1                   int64    path 'data.legacy.retweeted_status_result.result.legacy.display_text_range[0]'
         ,       data_legacy_retweet_display_text_range2                   int64    path 'data.legacy.retweeted_status_result.result.legacy.display_text_range[1]'
         ,       data_legacy_retweet_created_at                            varchar2 path 'data.legacy.retweeted_status_result.result.legacy.created_at'
         ,       data_legacy_retweet_conversation_id_str                   varchar2 path 'data.legacy.retweeted_status_result.result.legacy.conversation_id_str'
         ,       data_legacy_retweet_id_str                                varchar2 path 'data.legacy.retweeted_status_result.result.legacy.id_str'
         ,       data_legacy_retweet_user_id_str                           varchar2 path 'data.legacy.retweeted_status_result.result.legacy.user_id_str'
         ,       data_legacy_retweet_retweeted                             varchar2 path 'data.legacy.retweeted_status_result.result.legacy.retweeted'
         ,       data_legacy_retweet_retweet_count                         int64    path 'data.legacy.retweeted_status_result.result.legacy.retweet_count'
         ,       data_legacy_retweet_reply_count                           int64    path 'data.legacy.retweeted_status_result.result.legacy.reply_count'
         ,       data_legacy_retweet_quote_count                           int64    path 'data.legacy.retweeted_status_result.result.legacy.quote_count'
         ,       data_legacy_retweet_possible_sensitive_editable           varchar2 path 'data.legacy.retweeted_status_result.result.legacy.possibly_sensitive_editable'
         ,       data_legacy_retweet_possibly_sensitive                    varchar2 path 'data.legacy.retweeted_status_result.result.legacy.possibly_sensitive'
         ,       data_legacy_retweet_lang                                  varchar2 path 'data.legacy.retweeted_status_result.result.legacy.lang'
         ,       data_legacy_retweet_is_quote_status                       boolean  path 'data.legacy.retweeted_status_result.result.legacy.is_quote_status'
         ,       data_legacy_retweet_full_text                             varchar2 path 'data.legacy.retweeted_status_result.result.legacy.full_text'
         ,       data_legacy_retweet_favorited                             varchar2 path 'data.legacy.retweeted_status_result.result.legacy.favorited'
         ,       data_legacy_retweet_favorite_count                        int64    path 'data.legacy.retweeted_status_result.result.legacy.favorite_count'
         ,       data_legacy_retweet_entities_hashtags_json                varchar2 path 'data.legacy.retweeted_status_result.result.legacy.entities.hashtags'
         ,       data_legacy_retweet_entities_symbols_json                 varchar2 path 'data.legacy.retweeted_status_result.result.legacy.entities.symbols'
         ,       data_legacy_retweet_entities_timestamps_json              varchar2 path 'data.legacy.retweeted_status_result.result.legacy.entities.timestamps'
         ,       data_legacy_retweet_entities_urls_json                    varchar2 path 'data.legacy.retweeted_status_result.result.legacy.entities.urls'
         ,       data_legacy_retweet_entities_mention_user1_id             varchar2 path 'data.legacy.retweeted_status_result.result.legacy.entities.user_mentions[0].id_str'
         ,       data_legacy_retweet_entities_mention_user1_name           varchar2 path 'data.legacy.retweeted_status_result.result.legacy.entities.user_mentions[0].name'
         ,       data_legacy_retweet_entities_mention_user1_screen_name    varchar2 path 'data.legacy.retweeted_status_result.result.legacy.entities.user_mentions[0].screen_name'
         ,       data_legacy_retweet_entities_mention_user2_id             varchar2 path 'data.legacy.retweeted_status_result.result.legacy.entities.user_mentions[1].id_str'
         ,       data_legacy_retweet_entities_mention_user2_name           varchar2 path 'data.legacy.retweeted_status_result.result.legacy.entities.user_mentions[1].name'
         ,       data_legacy_retweet_entities_mention_user2_screen_name    varchar2 path 'data.legacy.retweeted_status_result.result.legacy.entities.user_mentions[1].screen_name'
         ,       data_legacy_retweet_entities_mention_user3_id             varchar2 path 'data.legacy.retweeted_status_result.result.legacy.entities.user_mentions[2].id_str'
         ,       data_legacy_retweet_entities_mention_user3_name           varchar2 path 'data.legacy.retweeted_status_result.result.legacy.entities.user_mentions[2].name'
         ,       data_legacy_retweet_entities_mention_user3_screen_name    varchar2 path 'data.legacy.retweeted_status_result.result.legacy.entities.user_mentions[2].screen_name'
Voeg for csv toe om er een CSV van te maken.
Let op: sommige velden kunnen regelovergangen bevatten. In de CSV-representatie komt dat er uit als:
"regel 1
regel 2
regel 3
Een CSV-parser moet hiermee om kunnen gaan zoals beschreven in RFC 4180: Common Format and MIME Type for Comma-Separated Values (CSV) Files sectie 2, regel 6 en 7.
