I use View.HourEntries2Years@sva but I missed the Created Time value (column).
Is that possible to add column for the created datetime for the row?
It would make it possible to calculate difference between eventdate and createddate.
From our documentation, the creation date is not available in the SOAP APIs provided for Visma Severa.
The following fields are available for an hour entry, when correct these all should be present already in the view (see also https://sync.severa.com/webservice/S3/API.svc/WSDL?singleWsdl):
<xs:complexType name="HourEntry">
<xs:sequence>
<xs:element minOccurs="0" name="AccountGUID" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="CaseBusinessUnitCode" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="CaseCostCenterIdentifier" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="CaseGUID" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="CaseName" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="CaseNumber" type="xs:long" />
<xs:element minOccurs="0" name="CostCurrencyShortform" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="CostCurrencyShortformOfInvoicingCurrency" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="CostCurrencyShortformOfOrganizationCurrency" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="CostCurrencyShortformOfUserCompanyCurrency" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="Description" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="EndTime" nillable="true" type="xs:dateTime" />
<xs:element minOccurs="0" name="EventDate" type="xs:dateTime" />
<xs:element minOccurs="0" name="GUID" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="InvoiceDescription" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="InvoiceGUID" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="InvoiceQuantity" nillable="true" type="xs:decimal" />
<xs:element minOccurs="0" name="InvoiceRowGUID" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="IsApproved" nillable="true" type="xs:boolean" />
<xs:element minOccurs="0" name="IsBillable" type="xs:boolean" />
<xs:element minOccurs="0" name="IsProductive" nillable="true" type="xs:boolean" />
<xs:element minOccurs="0" name="IsReadOnly" type="xs:boolean" />
<xs:element minOccurs="0" name="OverTimeGUID" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="OvertimeCode" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="PhaseGUID" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="PriceCurrencyShortformOfCaseCompanyCurrency" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="PriceCurrencyShortformOfInvoicingCurrency" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="PriceCurrencyShortformOfOrganizationCurrency" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="PriceCurrencyShortformOfUserCompanyCurrency" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="Quantity" type="xs:decimal" />
<xs:element minOccurs="0" name="StartTime" nillable="true" type="xs:dateTime" />
<xs:element minOccurs="0" name="TaskGUID" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="UnitCost" type="xs:decimal" />
<xs:element minOccurs="0" name="UnitCostInInvoicingCurrency" type="xs:decimal" />
<xs:element minOccurs="0" name="UnitCostInOrganizationCurrency" type="xs:decimal" />
<xs:element minOccurs="0" name="UnitCostInUserCompanyCurrency" type="xs:decimal" />
<xs:element minOccurs="0" name="UnitPrice" type="xs:decimal" />
<xs:element minOccurs="0" name="UnitPriceInBaseCurrency" type="xs:decimal" />
<xs:element minOccurs="0" name="UnitPriceInCaseCompanyCurrency" type="xs:decimal" />
<xs:element minOccurs="0" name="UnitPriceInUserCompanyCurrency" type="xs:decimal" />
<xs:element minOccurs="0" name="UserBusinessUnitCode" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="UserCode" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="UserFirstName" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="UserGUID" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="UserLastName" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="WorkTypeCode" nillable="true" type="xs:string" />
<xs:element minOccurs="0" name="WorkTypeGUID" nillable="true" type="xs:string" />
</xs:sequence>
</xs:complexType>
