Data Hub itgencun016: Error itgencmr006: itgen_no_provider_for_action_par1
Sinds vorige week doet onze connectie naar Exact Online het niet meer.
Twee keer per dag draait er een batchjob die data uit excat-online haalt.
Het volgende staat in de logfile:
*** General ***
Local Machine Code: kyJhYyqPSrwYUD2KWIW76A==
2023-07-03 21:10:31.620 Information itgendhb037: Logged 823 messages.
2023-07-05 06:47:38.717 Information itgendhb028: itgen_logging_started_par1 (D:\Invantive\Jobs\log\eol2sqlserver-202307.log)
2023-07-05 06:47:38.717 Information itgendhb038: Invantive Data Hub (22.0.341-PROD+3569)
2023-07-05 06:47:38.717 Information itgendhb039: (C) Copyright 2004-2022 Invantive Software BV, the Netherlands. All rights reserved.
2023-07-05 06:47:38.780 Information itgendhb023: itgen_sql_script_file: D:\Invantive\Jobs\sql\eol2sqlserver.sql
2023-07-05 06:47:38.781 Information itgendhb029: itgen_log_file: D:\Invantive\Jobs\log\eol2sqlserver-202307.log
2023-07-05 06:47:38.781 Information itgendhb066: itgen_license_contract_code:
2023-07-05 06:47:38.782 Information itgendhb076: itgen_license_key_id:
2023-07-05 06:47:38.789 Information itgendhb030: Database: acme\eol2sql
2023-07-05 06:47:38.791 Information itgendhb203: Logging on
2023-07-05 06:47:40.133 Information itgencmr138: itgen_opened_service_data_container_dot_par1 (OAuthHeadless)
2023-07-05 06:47:40.134 Information itgencmr138: itgen_opened_service_data_container_dot_par1 (TeamViewer)
2023-07-05 06:47:40.135 Information itgencmr138: itgen_opened_service_data_container_dot_par1 (KeePass)
2023-07-05 06:47:40.137 Information itgencmr138: itgen_opened_service_data_container_dot_par1 (Mail)
2023-07-05 06:47:40.138 Information itgencmr138: itgen_opened_service_data_container_dot_par1 (Ossus)
2023-07-05 06:47:40.139 Information itgencmr138: itgen_opened_service_data_container_dot_par1 (InMemoryStorage)
2023-07-05 06:47:40.141 Information itgencmr138: itgen_opened_service_data_container_dot_par1 (DataDictionary)
2023-07-05 06:47:40.141 Information itgencmr138: itgen_opened_service_data_container_dot_par1 (LastResort)
2023-07-05 06:47:40.205 Information itgencmr456: itgen_connecting_to_data_container_with_alias_par2 (Invantive Bridge Online) (bol)
2023-07-05 06:47:40.216 Information itgengpr065: itgen_opening_regular_data_container_dot_par1 (bol)
2023-07-05 06:47:46.611 Information itgengpr152: itgen_opened_regular_data_container_dot_par1 (bol)
2023-07-05 06:47:46.626 Information itgencmr456: itgen_connecting_to_data_container_with_alias_par2 (SQL Server) (sqlserver)
2023-07-05 06:47:46.628 Information itgengpr065: itgen_opening_regular_data_container_dot_par1 (sqlserver)
2023-07-05 06:47:47.912 Information itgengpr152: itgen_opened_regular_data_container_dot_par1 (sqlserver)
2023-07-05 06:47:47.935 Information itgencmr130: itgen_opened_database_dot_par1 (solidus - eol2sql)
2023-07-05 06:47:47.947 Information itgendhb205: itgen_connect_dot
2023-07-05 06:47:47.994 Error itgencun016: Error itgencmr006: itgen_no_provider_for_action_par1 (RestrictedAccessLogOn).
OAuthHeadless, InvantiveBridgeOnline (bol), SqlServer (sqlserver), TeamViewer, KeePass, Mail, Ossus, InMemoryStorage, DataDictionary, LastResort
2023-07-05 06:47:49.998 Error itgencmr006: ValidationException
   at Invantive.Basics.ValidationException..ctor(GlobalState owner, ExecutionOptions executionOptions, String messageCode, String errorMessage, String kindRequest, String localStackTrace, String nk, Exception innerException, Boolean inheritMessageCodeWhenPresent, Nullable`1 uid, Boolean isRecoverable, String poolIdentityId, String url)
   at Invantive.Data.ConnectionManager.IO(GlobalState , ExecutionOptions , String , ParameterList )
   at Invantive.Data.ConnectionManager.ExecuteAction(GlobalState owner, ExecutionOptions executionOptions, String action, ParameterList parameters)
   at Invantive.Data.ActionProceduresBase.ExecuteAction(GlobalState owner, ExecutionOptions executionOptions, String action, ParameterList parameters)
   at Invantive.Data.ActionProceduresBase.RestrictedAccessLogOn(GlobalState owner, ExecutionOptions executionOptions, String page, String method, String userLogonCode, String password, String action, IPAddress iPAddress, String hostName, String requestUrl, String sessionId, Boolean isAutoLogOn, Nullable`1 partition, String applicationName, String applicationVersion, String localUserLogonCode)
   at IDH.K.V.V(Object , DelayedLogOnEventArgs )
   at Invantive.Data.ConnectionManager.EO(GlobalState , ExecutionOptions , CredentialsContainer )
   at Invantive.Producer.UtilityBaseCore.CheckConnection(GlobalState owner, ExecutionOptions executionOptions, Boolean forceReconnect, Boolean silent, String databaseName, CredentialsContainer credentialsContainer)
   at IDH.K.U(String[] )
2023-07-05 06:47:49.999 Information itgencmr129: itgen_database_log_on_failed_dot (solidus - eol2sql)
2023-07-05 06:47:50.017 Information itgencmr140: itgen_provider_instance_closed_dot_par1 (bol)
2023-07-05 06:47:50.023 Information itgencmr140: itgen_provider_instance_closed_dot_par1 (sqlserver)
2023-07-05 06:47:50.024 Information itgencmr139: itgen_provider_instance_closed_dot_par1 (KeePass)
2023-07-05 06:47:50.024 Information itgencmr139: itgen_provider_instance_closed_dot_par1 (InMemoryStorage)
2023-07-05 06:47:50.026 Information itgencmr139: itgen_provider_instance_closed_dot_par1 (Ossus)
2023-07-05 06:47:50.030 Information itgencmr139: itgen_provider_instance_closed_dot_par1 (Mail)
2023-07-05 06:47:50.031 Information itgencmr139: itgen_provider_instance_closed_dot_par1 (DataDictionary)
2023-07-05 06:47:50.032 Information itgencmr132: itgen_closed_database_dot (acme - eol2sql)
2023-07-05 06:47:50.044 Error itgencun016: Error itgencmr398: itgen_could_not_connect_db_emptyuser_par1 (acme\eol2sql).
itgen_sql_cmr398_user_message
2023-07-05 06:47:50.047 Error itgencmr398: Invantive.Basics.InvantiveSqlException
ValidationException
   at Invantive.Basics.InvantiveSqlException..ctor(GlobalState owner, ExecutionOptions executionOptions, String validationCode, String errorMessage, String kindRequest, String stackTrace, String nk, Exception innerException, Boolean inheritMessageCodeWhenPresent, Nullable`1 uid, Boolean isRecoverable, String poolIdentityId)
2023-07-05 06:47:50.063 Error itgencun016: Error itgendhb005: itgen_dhb005_user_message_par1 (acme\eol2sql).
2023-07-05 06:47:50.064 Error itgendhb005: ValidationException
2023-07-05 06:47:50.076 Error itgenube182: itgendhb005: itgen_dhb005_user_message_par1 (acme\eol2sql).
For support go to https://forums.invantive.com.
2023-07-05 06:47:50.076 Information itgendhb219: itgen_exit_prg_code_par1 (5)
2023-07-05 06:47:50.077 Information itgendhb068: itgen_ended_time_par1 (5-7-2023 06:47:50)
2023-07-05 06:47:50.077 Information itgendhb036: *** HARD-WIRED MANIFEST ***
Company: Invantive Software B.V.
Product: Invantive Data Hub
Description Short: Invantive(R) Data Hub
Copyright: (C) Copyright 2004-2022 Invantive Software B.V., the Netherlands. All rights reserved.
Trademark: Invantive
Description: Invantive Data Hub is command-line driven software that is capable of executing Invantive Query Tool-compatible scripts across many database and cloud platforms. Ideal for high volume data loads and extractions of cloud applications such as Exact Online or Salesforce. It provides a headless mode which makes it ideal for use in server environments and scheduled uploads and downloads in lights-out operations. Invantive Data Hub is also an ideal execution environment for large data replication jobs using Invantive Data Replicator.
Configuration: Release
File Version: 22.0.341.3569
Version Label: 22.0.341-PROD+3569
Build Date: 8-9-2022 18:18:05
Obfuscated: True
Kan iemand mij uitleggen wat er mis gaat?
Advies is om allereerst een upgrade uit te voeren i.v.m. breaking changes op Exact Online. Hiervoor zal het nodig zijn om over te stappen van Microsoft .net Framework naar Microsoft .net core zoals beschreven in Overstappen van Windows- naar multi-platform variant van Data Hub.
Als het goed is, dan hebben alle Data Hub-gebruikers hier circa 14 dagen geleden een verzoek voor ontvangen.
Gelieve daarna nogmaals te proberen.
Een bericht is gesplitst naar een nieuw topic: Itgencsy020 foutmelding
