Itgenuty726 foutmelding Invantive Data Hub
Bij het verbinden naar Invantive Data Hub komt de volgende melding omhoog:
2026-07-23 07:44:51.348 Error itgencun016: Error itgenuty726: A connection could not be established to the database 'ACME\eolmss'.
The operation has timed out.
2026-07-23 07:44:53.360 Error itgenuty726: System.Net.WebException
ValidationException
   at Invantive.Data.Providers.OAuth.InvantiveOAuthCredentialsServerProvider.GetDatabaseConnectionInfo(GlobalState owner, ExecutionOptions executionOptions, SqlExecutionStep sqlExecutionStep, IProviderManager manager, SerializableCredentialsDataContainer dataContainer, Credentials credentials, String databaseFullName)
   at Invantive.Data.ConnectionManager.OpenDataContainerProviderCredentials(GlobalState owner, ExecutionOptions executionOptions, SqlExecutionStep sqlExecutionStep, SerializableDatabase database, SerializableCredentialsDataContainer dataContainer, Credentials credentials, ConcurrentBag`1 triedProviders, Boolean ignoreDecryptionErrors, Boolean& decryptionErrorsOccurred)
   at Invantive.Data.ConnectionManager.OpenDataContainerProvider(GlobalState owner, ExecutionOptions executionOptions, SqlExecutionStep sqlExecutionStep, SerializableDatabase database, DataContainer dataContainer, Credentials credentials, ConcurrentBag`1 triedProviders, Boolean ignoreDecryptionErrors, Boolean& decryptionErrorsOccurred)
   at Invantive.Data.ConnectionManager.<>c__DisplayClass371_0.<ProviderOpen>b__7(DataContainer, ParallelLoopState pls, Int64)
   at Invantive.Basics.ParallelUtility.<>c__DisplayClass4_0`1.<ForEachWithAggregatedExceptions>b__0(TSource tSource, ParallelLoopState parallelLoopState, Int64 index)
--- End of stack trace from previous location ---
   at Invantive.Basics.ErrorConstants.ThrowOneOrMoreExceptions(GlobalState owner, ExecutionOptions executionOptions, IEnumerable`1 exceptions)
   at Invantive.Basics.ParallelUtility.ForEachWithAggregatedExceptions[TSource](GlobalState owner, ExecutionOptions executionOptions, IEnumerable`1 source, ParallelOptions parallelOptions, Action`3 body, Boolean shuffle, Boolean useCancellationTokenFromExecutionOptions, Boolean keepGoingOnError)
   at Invantive.Data.ConnectionManager.ProviderOpen(GlobalState owner, ExecutionOptions executionOptions, SqlExecutionStep sqlExecutionStep, CredentialsContainer credentialsContainer, Boolean ignoreDecryptionErrors, Boolean& decryptionErrorsOccurred)
   at Invantive.Data.ConnectionManager.Open(GlobalState owner, ExecutionOptions executionOptions, SqlExecutionStep sqlExecutionStep, CredentialsContainer credentialsContainer, Boolean ignoreDecryptionErrors, Boolean& decryptionErrorsOccurred)
2026-07-23 07:44:53.384 Error itgencun016: Error itgendhb005: Could not connect to database 'ACME\eolmss'. Application will be closed.
2026-07-23 07:44:53.386 Error itgendhb005: ValidationException
   at Invantive.Basics.ValidationException..ctor(GlobalState owner, ExecutionOptions executionOptions, String messageCode, String errorMessage, String kindRequest, String localStackTrace, String nk, Exception innerException, Boolean inheritMessageCodeWhenPresent, Nullable`1 uid, Nullable`1 isRecoverable, String poolIdentityId, String url, Nullable`1 partyUid, String partitionCode, String tableName, String parameter1, String parameter2, String parameter3, String parameter4, String parameter5, String clientId)
   at Invantive.Producer.Data.Hub.QueryEngine.Run(GlobalState owner, ExecutionOptions executionOptions, String[] arguments)
   at Invantive.Producer.Data.Hub.Program.Main(String[] args)
   at Invantive.Producer.Data.Hub.QueryEngine.Run(GlobalState owner, ExecutionOptions executionOptions, String[] arguments) in c:\smoke\ws-26.0\Invantive.Data.Hub\src\Invantive.Producer.Data.Hub\QueryEngine.cs:line 613
2026-07-23 07:44:53.391 Error itgendhb005: Could not connect to database 'ACME\eolmss'. Application will be closed.
Hoe lossen we dit op?
Vanuit de monitoring is de volgende melding te zien:
Authentication failed:
Te veel opeenvolgende ongeldige aanmeldpogingen voor gebruiker ‘***’.
De eerste mislukte poging was op 22-07-2026 03:35:57 (UTC) en de laatste om 23-07-2026 08:36:21 (UTC).
Controleer of u met deze aanmeldcode op de Invantive Cloud-website kunt aanmelden en probeer het na 23-07-2026 09:10:58 (UTC) opnieuw.
Controleer:
  • of de gebruiker waarmee aangemeld wordt op de Credentials server een gebruiker is van de eigenaar van de database of delegatie heeft;
  • of het wachtwoord correct is door zich daarmee aan te melden op Invantive Cloud of Bridge Online;
  • de gebruiker een service account is;
  • of de database gebruik van Credentials Server toestaat;
  • of het IP-adres toegestaan in binnen de database.
Gezien de foutmelding is het waarschijnlijk dat het eerste of twee punt het probleem is.
Ik begrijp hier helemaal niets van. Een consultant van Invantive heeft dit ingesteld. Ik heb mijn account van exact online gebruikt en ingelogd. Dit heb ik vanochtend weer gedaan!
Hoe kan ik dit checken?
In Invantive Cloud onder Gebruikers.
Door zich met die aanmeldgegevens op Invantive Bridge Online aan te melden.
Dit lijkt goed te gaan.
Lukt het nu dan ook via de software?
Sorry, nog 1 poging alsjeblieft. Ik zag een aanmeldpoging binnenkomen, maar die werkte nog niet.
De aanmeldpogingen lijken via [redacted] te gaan
Wat zie je daarvan?
Ik zie inderdaad een poging binnenkomen. Kan je die nogmaals doen?
Zie jij nu of dit goed loopt?
Ja, het aanmelden gaat nu goed. Ik kan vanaf hier de reden niet zien. Is het mogelijk dat vanochtend meerdere malen met de verkeerde aanmeldgegevens is aangemeld?
Er is niets gewijzigd vanaf onze kant
Ik zie nog geen nieuwe data in exact online…
Advies is om de beheerder van uw omgeving te betrekken.
