Het inladen van Exact Online data naar een Azure SQL database levert onderstaande fout op.
Versie Query Tool: Query Tool - 22.0.66-PROD+2350
Wat kunnen we uitvoeren om de synchronisatie correct te laten lopen?
itgendch372: Statement #1 'use XXXXXX@eo...Periods@eolbe;' beginnend op regel 1 veroorzaakte een fout.
The repository can not be opened due to errors.
Backing-database van Invantive Data Replicator kan niet worden geopend.
Kan geen repositoryview maken in groep '050', SQL begint met 'create view {{viewnameprefix}}warning...'.
Operand data type datetime2 is invalid for subtract operator.
Please resolve the errors first and then try again.
Bericht ID: 89f5dc15-e788-4e2d-86c4-c8fed70715a3
Opgetreden (UTC): 9/03/2022 19:57:10
use XXXXXX@eolbe;
SELECT * FROM ExactOnlineREST.Financial.FinancialPeriods@eolbe;
System.Data.SqlClient.SqlException
ValidationException
ValidationException
ValidationException
ValidationException
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite)
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
at Invantive.Data.AnsiSqlProviderBase.PassthroughSqlAction(GlobalState owner, ExecutionOptions executionOptions, String actionSql, ParameterList parameters, String loggingTableName)
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at Invantive.Data.Providers.DataCache.DataCacheProvider.TWL(GlobalState , ExecutionOptions , String , Boolean , String )
