A few weeks ago (4 to 5), we received an export for the first time from an application running on the Invantive platform, which showed all values as negative.
We only noticed this once, and the following day everything was fine again, so we didn’t do anything further about it. However, over the past week, every export has had negative numbers. We use this export to import turnover and order amounts elsewhere, which is now going completely wrong. We haven’t made any changes on our end. What is the cause of this (a change at Exact?), and what can we do to get this working correctly again?
A reproduction scenario provides information about triggering the problem as concretely as possible, in as few steps as possible.
Adding source code from Power Query is discouraged, as this shifts the issue to Power Query. A better alternative is the corresponding Invantive UniversalSQL statement where the characters also come out incorrectly.
A case with number 05361446 has been created with Exact Online Support regarding the flipping of the sign for amount fields in the sync APIs:
Approximately 5 weeks ago, the sync API /SalesInvoice/SalesInvoices, as accessible via SalesInvoiceLinesIncremental, suddenly started returning a different sign for amount fields such as AmountDC for LineNumber 0.
This only occurred in the Netherlands, not in identical environments in Germany and the United Kingdom.
After a day, this issue disappeared.
Due to a frozen period ahead of the introduction of 25.0, Invantive Bridge Online did not change version during that time.
Over the past week, the issue has started occurring structurally in all three of the countries mentioned.
A response has been received: after checking in several (older) versions, this behaviour is as expected and the action/response is the same. Nothing has changed in the API since 2022 in terms of code in this API, so a change is not to be expected.
From Invantive’s side, likewise.
This is contradictory, but the good news is that the current behaviour is not classified as a bug and will continue to be used.
This question was automatically closed after 1 week of inactivity. The last answer given has been marked as the solution.
