Probleem zoals beschreven bij Error itgendhb212: External error in Invantive Data Hub. (out of memory) treedt weer op (bij andere klant).
Dit keer werkt het toevoegen niet van de regel voor uitschakelen disk cache.
Hierbij een iets uitgebreidere versie van de foutmelding. Enig idee waar dit door komt?
One or more errors occurred.
Exception of type ‘System.OutOfMemoryException’ was thrown.
2021-04-29 09:07:23.297 Error itgenclr007: System.OutOfMemoryException
at System.IO.MemoryStream.ToArray()
at Invantive.Data.Providers.ExactOnline.ChunkedDiskCacheStream.T()
at Invantive.Data.Providers.ExactOnline.ChunkedDiskCacheStream.Close()
at Invantive.Data.Providers.ExactOnline.ExactOnlineRestProvider.IQU.MoveNext()
at Invantive.Data.GenericProvider.QSC.MoveNext()
at (Object )
at IBC.DF.R(Object )
at Invantive.Basics.ExtensionMethods.ZB1.MoveNext() at Invantive.Data.Providers.DataCache.DataCacheProvider.MaintainTablePartitionVersionFactsOnePartition(GlobalState owner, ExecutionOptions executionOptions, ObjectDefinition objectDefinition, DatabaseColumnDefinitionCollection resultFields, Lazy1 fetchFullDataSet, Boolean mayReplaceWithCachedData, String sourceDataContainerId, String partitionCode, IDataProvider dataSourceProvider, QueryObject originalQueryObject, Nullable1 maxAgeDataMs, Decimal version, DcTablePartitionVersion previousReadyTablePartitionVersion, String refreshOrigin, PartitionData& replacementPartitionData) at Invantive.Data.Providers.DataCache.DataCacheProvider.RefreshTablePartition(GlobalState owner, ExecutionOptions executionOptions, IProviderManager manager, Decimal tablePartitionId, String sourceDataContainerId, String dataContainerAlias, String fullQualifiedName, String partitionCode, Nullable1 versionLast, DcUpdateStrategy originalUpdateStrategy, Decimal dcrId, Decimal ptnId, Decimal tbeId, Int64& countWithDefaultLoading, Int64& countWithSmartSampling, Int64& countWithTrickleLoading, Nullable1& maxIncomingMessageId, Boolean& usedCompleteCopyInsteadOfTrickleLoading) at Invantive.Data.Providers.DataCache.DataCacheProvider.RefreshObsoleteTablePartitionsPerPartition(GlobalState owner, ExecutionOptions executionOptions, IProviderManager manager, String dataContainerId, String dataContainerAlias, String partitionName, VUH[] obsoleteTablePartitions, Int64 parallelLoopIndex, DcUpdateStrategy forcedUpdateStrategy, ConcurrentBag1 allExceptions, Int64& countWithDefaultLoading, Int64& countWithSmartSampling, Int64& countWithTrickleLoading, Int64& countUpdatedTablePartitions, Int64& countNoActionTablePartitions, Int64& countFailedTablePartitions, Int64& countWithFallbackToCompleteCopy)
at Newtonsoft.Json.JsonTextReader.PrepareBufferForReadData(Boolean append, Int32 charsRequired)
at Newtonsoft.Json.JsonTextReader.ReadData(Boolean append, Int32 charsRequired)
at Newtonsoft.Json.JsonTextReader.ReadStringIntoBuffer(Char quote)
at Newtonsoft.Json.JsonTextReader.ParseString(Char quote, ReadType readType)
at Newtonsoft.Json.JsonTextReader.ReadAsBytes()
at Newtonsoft.Json.JsonReader.ReadForType(JsonContract contract, Boolean hasConverter)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateValueInternal(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent)
at Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType)
at Newtonsoft.Json.JsonSerializer.Deserialize[T](JsonReader reader)
at Invantive.Basics.HttpResponseCacheObject.FromJson(GlobalState owner, ExecutionOptions executionOptions, String json, String& reasonNull)
at Invantive.Data.GenericProvider.TryGetHttpFromDiskCache(GlobalState owner, ExecutionOptions executionOptions, CacheSettings cacheSettings, String cacheId, Nullable`1 maxAgeSec, Boolean expectEncryption, String expectedUrl, String dataContainerId, HttpResponseCacheObject& cacheObject)
at Invantive.Data.Providers.ExactOnline.ExactOnlineRestProvider.DQU.V(ReadChunkData )
at Invantive.Data.Providers.ExactOnline.ChunkedDiskCacheStream.P()
at Invantive.Data.Providers.ExactOnline.ChunkedDiskCacheStream.V(Byte , Int32 , Int32 )
at Invantive.Data.Providers.ExactOnline.ChunkedDiskCacheStream.Read(Byte buffer, Int32 offset, Int32 count)
at System.IO.StreamReader.ReadBuffer(Char userBuffer, Int32 userOffset, Int32 desiredChars, Boolean& readToUserBuffer)
at System.IO.StreamReader.Read(Char buffer, Int32 index, Int32 count)
at Newtonsoft.Json.JsonTextReader.ParseValue()
