Itgenclr008-fout bij het downloaden in Power BI
Please assist with the error below, OData Update from Power BI Australia
DataSource.Error: Microsoft.Mashup.Engine1.Library.Resources.HttpResource: Request failed:
OData Version: 3 and 4, Error: The remote server returned an error: (500) Internal Server Error. (An internal error of type ‘382152’ occurred. Please contact your supplier. (itgenclr008, e0d3a78b-55cb-4c81-bb94-3ecba17aab8f))
SessionID: 4a70bad1-ea48-4c7d-b8b6-afe66f4ff6c1
RequestID: 473960d6-c547-4767-9e8d-3f738cb6c30d
Is it possible to add a (anonymized) screenshot of the request details in Invantive Bridge Online Monitoring as described in More insight with new Bridge Online Monitoring?
Details can be found by clicking on the download request which represents the issue discussed in this topic.
Please leave at least the following data visible:
  • the status code, network size and times in the left column,
  • the entire right column.
I have the exact same error message since yesterday when accessing the OData feed.
Thanks for the valuable addition.
The probable root cause has been established. It may cause many or all Swagger/OpenAPI-based drivers to fail with an error when opening the database. It is a regression bug that went undetected during automated tests.
A fix has been established and will be taken into production on Invantive Cloud within 4 hours. For on-premises products, an upgrade with the expected fix can be found after the same time on https://releasenotes.invantive.com.
An upgrade has been taken into production for Invantive Cloud.
Please retry your operation.
All sorted and tested OK. Thank You
Works for me as well. Thanks!
