Itgenuty427 "Ontbrekende status" bij starten van Invantive Data Hub
Bij het gebruik van Invantive Data Hub 24.0.424 met Exact Online treedt sinds 21 november 2024 09:00 de volgende melding op:
itgenuty427
Missing state.
als in:
2024-11-22 00:00:23.710 Error itgencun016: Error itgenuty427: A connection to the database group\database could not be established.
One or more errors occurred.
Missing state.
2024-11-22 00:00:25.711 Error itgenuty427: InvantiveSystemException
   at Invantive.Basics.ValidationException..ctor(GlobalState owner, ExecutionOptions executionOptions, String messageCode, String errorMessage, String kindRequest, String localStackTrace, String nk, Exception innerException, Boolean inheritMessageCodeWhenPresent, Nullable`1 uid, Nullable`1 isRecoverable, String poolIdentityId, String url, Nullable`1 partyUid, String partitionCode, String tableName, String parameter1, String parameter2, String parameter3, String parameter4, String parameter5, String clientId)
   at Invantive.Basics.InvantiveSystemException..ctor(GlobalState owner, ExecutionOptions executionOptions, String validationCode, String errorMessage, String kindRequest, String stackTrace, String nk, Exception innerException, Boolean inheritMessageCodeWhenPresent, Nullable`1 uid, Boolean isRecoverable, String poolIdentityId, String partitionCode, String tableName, String parameter1, String parameter2, String parameter3, String parameter4, String parameter5, String clientId)
   at Invantive.Data.OAuth.OAuthBackgroundProvider.GetOAuthAccessTokenForEOL(GlobalState owner, ExecutionOptions executionOptions, SqlExecutionStep sqlExecutionStep, SerializableDatabase database, DataContainer dataContainer, String providerName, OAuthInformation oauthInfo, Credentials credentials)
   at Invantive.Data.OAuth.OAuthBackgroundProvider.Invantive.Data.IOAuthProvider.GetOAuthToken(GlobalState owner, ExecutionOptions executionOptions, SqlExecutionStep sqlExecutionStep, SerializableDatabase database, DataContainer dataContainer, OAuthInformation oauthInfo, Credentials credentials)
   at Invantive.Data.ConnectionManager.ExecuteGetOAuthToken(GlobalState owner, ExecutionOptions executionOptions, SqlExecutionStep sqlExecutionStep, SerializableDatabase database, DataContainer dataContainer, OAuthInformation oauthInfo, Credentials credentials)
Deze foutmelding trad niet op op 21 november 2024 onder versie 24.0.424.
De problemen bij het gebruik van One Exact Identity, Exact Online en Invantive Data Hub worden centraal opgevolgd via de pagina Data Hub issues on Exact Online authentication.
U kunt zich aldaar abonneren op updates.
