We verkrijgen sinds gisteren een fout bij het opbouwen van verbinding met Teamleader via Data Hub 20.1.386.
Via de Query Tool lukt het inloggen wel nog.
Data Hub 20.1.478 heeft het zelfde probleem:
Configuratie in de settings.xml:
<database
order="0"
alias="tl"
provider="Teamleader"
userLogonCodeMode="Hidden"
passwordMode="Hidden"
defaultUserLogonCode="username"
defaultPassword="pw"
connectionString="api-group-authentication=false" />
Foutmelding:
itgen_cloud_obr024_user_message_par1 (window.location="https:\/\/focus.teamleader.eu\/dashboard.php";).
2021-07-17 08:20:57.074 Error itgenobr024: Invantive.Basics.InvantiveSqlException
ValidationException
at Invantive.Basics.ValidationException..ctor(GlobalState owner, ExecutionOptions executionOptions, String messageCode, String messageText, String kindRequest, String localStackTrace, String nk, Exception innerException, Boolean inheritMessageCodeWhenPresent, Nullable`1 uid, Boolean isRecoverable, String poolIdentityId)
at Invantive.Basics.InvantiveSqlException..ctor(GlobalState owner, ExecutionOptions executionOptions, String validationCode, String errorMessage, String kindRequest, String stackTrace, String nk, Exception innerException, Boolean inheritMessageCodeWhenPresent, Nullable`1 uid, Boolean isRecoverable, String poolIdentityId)
at Invantive.Data.OAuth.OAuthBackgroundProvider.ADQ(GlobalState , ExecutionOptions , String , OAuthInformation , Credentials )
at Invantive.Data.OAuth.OAuthBackgroundProvider.FUK(GlobalState , ExecutionOptions , OAuthInformation , Credentials )
at Invantive.Data.ConnectionManager.KT(GlobalState , ExecutionOptions , OAuthInformation , Credentials )
at Invantive.Data.ConnectionManager.FT(GlobalState , ExecutionOptions , OAuthInformation , Credentials )
at Invantive.Data.ConnectionManager.GetOAuthTokenForConnection(GlobalState owner, ExecutionOptions executionOptions, SerializableDatabase database, DataContainer dataContainer, ISupportsOAuth provider, Credentials credentials, Boolean ignoreDecryptionErrors, Boolean& decryptionErrorsOccurred)
at Invantive.Data.ConnectionManager.ET(GlobalState , ExecutionOptions , IConnectionDataProvider , SerializableDatabase , DataContainer , Credentials , Boolean , Boolean& )
at Invantive.Data.ConnectionManager.OpenDataContainerProvider(GlobalState owner, ExecutionOptions executionOptions, SerializableDatabase database, DataContainer dataContainer, Credentials credentials, List`1 triedProviders, Boolean ignoreDecryptionErrors, Boolean& decryptionErrorsOccurred)
at Invantive.Data.ConnectionManager.QT(GlobalState , ExecutionOptions , CredentialsContainer , Boolean , Boolean& )
at Invantive.Producer.UtilityBaseCore.CheckConnection(GlobalState owner, ExecutionOptions executionOptions, Boolean forceReconnect, Boolean silent, String databaseName, CredentialsContainer credentialsContainer)
at IDH.T.SI(String[] )
2021-07-17 08:20:57.152 Error itgencun016: Fout itgendhb005: Could not connect to database 'customer\data-replicator'. Application will be closed.
2021-07-17 08:20:57.152 Error itgendhb005: ValidationException
2021-07-17 08:20:57.184 Error itgenube182: itgendhb005: Could not connect to database 'customer\data-replicator'. Application will be closed.
Hoe kan ik dit oplossen?
