Na het updaten naar de nieuwe versie van de Data Hub (20.2.15), die de authenticatie met Teamleader gefixt zou moeten hebben, treedt er een nieuwe foutmelding op.
Deze komt enkel voor wanneer ik met Teamleader probeer te verbinden. Verbinding met bijvoorbeeld SQL Server gaat wel goed.
Kunnen jullie hiernaar kijken?
Error itgencun016: Fout itgenuty726: Er kan geen verbinding worden gemaakt met de database '***'.
The 'referer' header must be modified using the appropriate property or method.
Parameter name: name.
2021-09-21 07:55:39.059 Error itgenuty726: System.ArgumentException
ValidationException
at System.Net.WebHeaderCollection.ThrowOnRestrictedHeader(String headerName)
at System.Net.WebHeaderCollection.Set(String name, String value)
at Invantive.Data.OAuth.OAuthBackgroundProvider.GetOAuthAccessTokenForTeamleader(GlobalState owner, ExecutionOptions executionOptions, String providerName, OAuthInformation oauthInfo, Credentials credentials)
at Invantive.Data.OAuth.OAuthBackgroundProvider.Invantive.Data.IOAuthProvider.GetOAuthToken(GlobalState owner, ExecutionOptions executionOptions, OAuthInformation oauthInfo, Credentials credentials)
at Invantive.Data.ConnectionManager.EZ(GlobalState , ExecutionOptions , OAuthInformation , Credentials )
at Invantive.Data.ConnectionManager.OZ(GlobalState , ExecutionOptions , OAuthInformation , Credentials )
at Invantive.Data.ConnectionManager.GetOAuthTokenForConnection(GlobalState owner, ExecutionOptions executionOptions, SerializableDatabase database, DataContainer dataContainer, ISupportsOAuth provider, Credentials credentials, Boolean ignoreDecryptionErrors, Boolean& decryptionErrorsOccurred)
at Invantive.Data.ConnectionManager.LZ(GlobalState , ExecutionOptions , IConnectionDataProvider , SerializableDatabase , DataContainer , Credentials , Boolean , Boolean& )
at Invantive.Data.ConnectionManager.OpenDataContainerProvider(GlobalState owner, ExecutionOptions executionOptions, SerializableDatabase database, DataContainer dataContainer, Credentials credentials, List`1 triedProviders, Boolean ignoreDecryptionErrors, Boolean& decryptionErrorsOccurred)
at Invantive.Data.ConnectionManager.ZZ(GlobalState , ExecutionOptions , CredentialsContainer , Boolean , Boolean& )
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
2021-09-21 07:55:39.216 Error itgencun016: Fout itgendhb005: Kan geen verbinding maken met database 'Event Creators\ectl'. De Applicatie wordt gesloten.
2021-09-21 07:55:39.216 Error itgendhb005: ValidationException
at Invantive.Basics.ValidationException..ctor(GlobalState owner, ExecutionOptions executionOptions, String messageCode, String messageText, String kindRequest, String localStackTrace, String nk, Exception innerException, Boolean inheritMessageCodeWhenPresent, Nullable`1 uid, Boolean isRecoverable, String poolIdentityId)
at IDH.O.L(String[] )
2021-09-21 07:55:39.247 Error itgenube182: itgendhb005: Kan geen verbinding maken met database '***'. De Applicatie wordt gesloten.
