I’m trying to follow this guide to disable custom field domain value validation. Where can I find the option to force-custom-field-to-string as shown in the screenshot? I can’t seem to find the menu shown in the screenshot. Any help is much appreciated!
There should be a field named similar to “Represent custom field values as text”, which you can set to True
Thank you. Where do I go to find this field, though? I haven’t been able to find it on the invantive website.
You mean in Invantive Cloud?
Yes, I don’t know how to navigate to a page or window where I can change this field.
Using Invantive Cloud you have to specify this property manually. You can add ;force-custom-field-to-string=true
at the end of the connection string of the data container concerned.
Awesome, that worked!
