When I try to load the Deals table from Active Campaign. ActiveCampaign.V3.Deals@acn.
The error Unexpected error: Unable to translate bytes [8B] at index 1 from specified code page to Unicode. Occurs.
Microsoft.Mashup.Evaluator.Interface.ErrorException: Unable to translate bytes [8B] at index 1 from specified code page to Unicode. —> System.Text.DecoderFallbackException: Unable to translate bytes [8B] at index 1 from specified code page to Unicode. —> System.Text.DecoderFallbackException: Unable to translate bytes [8B] at index 1 from specified code page to Unicode.
at System.Text.DecoderExceptionFallbackBuffer.Throw(Byte bytesUnknown, Int32 index)
at System.Text.DecoderExceptionFallbackBuffer.Fallback(Byte bytesUnknown, Int32 index)
at System.Text.DecoderFallbackBuffer.InternalFallback(Byte bytes, Byte* pBytes, Char*& chars)
at System.Text.UTF8Encoding.GetChars(Byte* bytes, Int32 byteCount, Char* chars, Int32 charCount, DecoderNLS baseDecoder)
at System.Text.DecoderNLS.GetChars(Byte bytes, Int32 byteIndex, Int32 byteCount, Char chars, Int32 charIndex, Boolean flush)
at System.Text.DecoderNLS.GetChars(Byte bytes, Int32 byteIndex, Int32 byteCount, Char chars, Int32 charIndex)
at System.IO.StreamReader.ReadBuffer(Char userBuffer, Int32 userOffset, Int32 desiredChars, Boolean& readToUserBuffer)
at System.IO.StreamReader.Read(Char buffer, Int32 index, Int32 count)
at Microsoft.OData.Json.JsonReader.ReadInput()
at Microsoft.OData.Json.JsonReader.SkipWhitespaces()
at Microsoft.OData.Json.JsonReader.Read()
at Microsoft.OData.Json.BufferingJsonReader.ReadInternal()
at Microsoft.OData.Json.BufferingJsonReader.ReadNextAndCheckForInStreamError()
at Microsoft.OData.JsonLight.ODataJsonLightDeserializer.ReadPayloadStartImplementation(ODataPayloadKind payloadKind, PropertyAndAnnotationCollector propertyAndAnnotationCollector, Boolean isReadingNestedPayload, Boolean allowEmptyPayload)
at Microsoft.OData.JsonLight.ODataJsonLightDeserializer.ReadPayloadStart(ODataPayloadKind payloadKind, PropertyAndAnnotationCollector propertyAndAnnotationCollector, Boolean isReadingNestedPayload, Boolean allowEmptyPayload)
at Microsoft.OData.JsonLight.ODataJsonLightReader.ReadAtStartImplementation()
at Microsoft.OData.ODataReaderCore.ReadImplementation()
at Microsoft.OData.ODataReaderCore.InterceptException[T](Func1 action) at Microsoft.Mashup.Engine1.Library.OData.V4_7.Reader.ODataReaderEnumerator.Read() at Microsoft.Mashup.Engine1.Library.OData.V4_7.Reader.ODataReaderEnumerator.Start() at Microsoft.Mashup.Engine1.Library.OData.V4_7.Reader.ODataReaderEnumerator.MoveNext() at Microsoft.Mashup.Engine1.Runtime.SkipTakeEnumerator1.MoveNext()
at Microsoft.Mashup.Engine1.Runtime.RetryQuery.RetryEnumerator.MoveNext()
at Microsoft.Mashup.Evaluator.SimpleDocumentEvaluator.ValuePreviewValueSource.TableValuePreviewValueSource.SerializeRows(Int32 count)
at Microsoft.Mashup.Evaluator.SimpleDocumentEvaluator.ValuePreviewValueSource.TableValuePreviewValueSource.get_SmallValue()
at Microsoft.Mashup.Evaluator.Interface.TracingPreviewValueSource.get_SmallValue()
at Microsoft.Mashup.Evaluator.RemotePreviewValueSource.<>c__DisplayClass0_0.b__0()
at Microsoft.Mashup.Evaluator.EvaluationHost.ReportExceptions(String entryName, IEngineHost engineHost, IMessageChannel channel, Action action)
— End of inner exception stack trace —
at Microsoft.Mashup.Evaluator.EvaluationHost.<>c__DisplayClass26_0.b__1()
at Microsoft.Mashup.Common.SafeExceptions.IgnoreSafeExceptions(IEngineHost host, IHostTrace trace, Action action)
at Microsoft.Mashup.Evaluator.EvaluationHost.TryReportException(IHostTrace trace, IEngineHost engineHost, IMessageChannel channel, Exception exception)
at Microsoft.Mashup.Evaluator.RemoteDocumentEvaluator.Service.<>c__DisplayClass12_01.<OnBeginGetResult>b__0() at Microsoft.Mashup.Evaluator.EvaluationHost.ReportExceptions(IHostTrace trace, IEngineHost engineHost, IMessageChannel channel, Action action) at Microsoft.Mashup.Evaluator.RemoteDocumentEvaluator.Service.OnBeginGetResult[T](IMessageChannel channel, BeginGetResultMessage message, Action1 action)
at Microsoft.Mashup.Evaluator.RemoteDocumentEvaluator.Service.OnBeginGetPreviewValueSource(IMessageChannel channel, BeginGetPreviewValueSourceMessage message)
at Microsoft.Mashup.Evaluator.MessageHandlers.TryDispatch(IMessageChannel channel, Message message)
at Microsoft.Mashup.Evaluator.ChannelMessenger.ChannelMessageHandlers.TryDispatch(IMessageChannel channel, Message message)
at Microsoft.Mashup.Evaluator.MessageHandlers.Dispatch(IMessageChannel channel, Message message)
at Microsoft.Mashup.Evaluator.ChannelMessenger.OnMessageWithUnknownChannel(IMessageChannel baseChannel, MessageWithUnknownChannel messageWithUnknownChannel)
at Microsoft.Mashup.Evaluator.EvaluationHost.Run()
at Microsoft.Mashup.Container.EvaluationContainerMain.Run(Object args)
at Microsoft.Mashup.Evaluator.SafeThread2.<>c__DisplayClass9_0.b__0(Object o)
at Microsoft.Mashup.Container.EvaluationContainerMain.SafeRun(String args)
at Microsoft.Mashup.Container.EvaluationContainerMain.Main(String args)
at Microsoft.Mashup.Evaluator.EvaluationHost.OnException(IEngineHost engineHost, IMessageChannel channel, ExceptionMessage message)
at Microsoft.Mashup.Evaluator.Interface.IMessageChannelExtensions.WaitFor[T](IMessageChannel channel)
at Microsoft.Mashup.Evaluator.RemotePreviewValueSource.PreviewValueSource.WaitFor(Func1 condition, Boolean disposing) at Microsoft.Mashup.Evaluator.RemotePreviewValueSource.PreviewValueSource.get_SmallValue() at Microsoft.Mashup.Evaluator.Interface.TracingPreviewValueSource.get_SmallValue() at Microsoft.Mashup.Host.Document.Analysis.PackageDocumentAnalysisInfo.PackagePartitionAnalysisInfo.SetPreviewValue(EvaluationResult21 result, Func1 getStaleSince, Func1 getSampled)
Is there anything I can do to resolve this issue?
