Data Hub-installatie mislukt - Kan niet uitpakken naar tijdelijke map. Cabinet foutcode 1 / 1603
I just tried to update from 20.0.140 to the most recent version of Data Hub, but it seems like I cannot install this due to an extraction failure. This has been tried on a server and a personal computer.
It does not seem like it is fixable from my side. Let me know if it is.
Info: === Logging started: 27-5-2021  16:19:46 ===
CommonData: Message type: 0, Argument: 1033
CommonData: Message type: 1, Argument: Invantive Data Hub 20.0
ActionStart: Action 16:19:46: INSTALL.
Info: Action start 16:19:46: INSTALL.
CommonData: 1: 0 2: 1033 3: 1252
Info: === Logging started: 27-5-2021  16:19:47 ===
ActionStart: Action 16:19:47: INSTALL.
Info: Action start 16:19:47: INSTALL.
InstallStart: 1: Invantive Data Hub 20.0 2: {AC86D1C0-85AB-4839-8E40-1FB240099400}
ActionStart: Action 16:19:47: FindRelatedProducts. Searching for related applications
Info: Action start 16:19:47: FindRelatedProducts.
ActionData: Found application: {AC86D1C0-85AB-4839-8E40-1FB24008E400}
Info: Action ended 16:19:47: FindRelatedProducts. Return value 1.
ActionStart: Action 16:19:47: WixSharp_InitRuntime_Action.
Info: Action start 16:19:47: WixSharp_InitRuntime_Action.
Info: SFXCA: Extracting custom action to temporary directory: C:\Windows\Installer\MSIFA7A.tmp-\
Info: SFXCA: Binding to CLR version v4.0.30319
Info: Calling custom action WixSharp!WixSharp.ManagedProjectActions.WixSharp_InitRuntime_Action
Info: Action ended 16:19:48: WixSharp_InitRuntime_Action. Return value 1.
ActionStart: Action 16:19:48: AppSearch. Searching for installed applications
Info: Action start 16:19:48: AppSearch.
ActionData: Property: NETFRAMEWORK45, Signature: NetFramework45
Info: Action ended 16:19:48: AppSearch. Return value 1.
ActionStart: Action 16:19:48: LaunchConditions. Evaluating launch conditions
Info: Action start 16:19:48: LaunchConditions.
Info: Action ended 16:19:48: LaunchConditions. Return value 1.
ActionStart: Action 16:19:48: ValidateProductID.
Info: Action start 16:19:48: ValidateProductID.
Info: Action ended 16:19:48: ValidateProductID. Return value 1.
ActionStart: Action 16:19:48: CostInitialize. Computing space requirements
Info: Action start 16:19:48: CostInitialize.
Info: Action ended 16:19:48: CostInitialize. Return value 1.
ActionStart: Action 16:19:48: FileCost. Computing space requirements
Info: Action start 16:19:48: FileCost.
Info: Action ended 16:19:48: FileCost. Return value 1.
ActionStart: Action 16:19:48: CostFinalize. Computing space requirements
Info: Action start 16:19:48: CostFinalize.
Info: Action ended 16:19:48: CostFinalize. Return value 1.
ActionStart: Action 16:19:48: Set_ARPINSTALLLOCATION.
Info: Action start 16:19:48: Set_ARPINSTALLLOCATION.
Info: Action ended 16:19:48: Set_ARPINSTALLLOCATION. Return value 1.
ActionStart: Action 16:19:48: InstallValidate. Validating install
Info: Action start 16:19:48: InstallValidate.
Info: Action ended 16:19:49: InstallValidate. Return value 1.
ActionStart: Action 16:19:49: SET_COMPANYNAME.
Info: Action start 16:19:49: SET_COMPANYNAME.
Info: Action ended 16:19:49: SET_COMPANYNAME. Return value 1.
ActionStart: Action 16:19:49: SET_PRODUCTNAMEWITHOUTMARKS.
Info: Action start 16:19:49: SET_PRODUCTNAMEWITHOUTMARKS.
Info: Action ended 16:19:49: SET_PRODUCTNAMEWITHOUTMARKS. Return value 1.
ActionStart: Action 16:19:49: SET_VERSION3ELEMENTS.
Info: Action start 16:19:49: SET_VERSION3ELEMENTS.
Info: Action ended 16:19:49: SET_VERSION3ELEMENTS. Return value 1.
ActionStart: Action 16:19:49: SetNonElevatedUserAction.
Info: Action start 16:19:49: SetNonElevatedUserAction.
Info: SFXCA: Extracting custom action to temporary directory: C:\Windows\Installer\MSI151.tmp-\
Info: SFXCA: Failed to extract to temporary directory. Cabinet error code 1.
Info: CustomAction SetNonElevatedUserAction returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
Info: Action ended 16:19:49: SetNonElevatedUserAction. Return value 3.
Info: Action ended 16:19:49: INSTALL. Return value 3.
InstallEnd: 1: Invantive Data Hub 20.0 2: {AC86D1C0-85AB-4839-8E40-1FB240099400} 3: 3
CommonData: 1: 2 2: 0
CommonData: 1: 2 2: 1
A 1603 often signals that there are Windows updates to be finished or installed. Please make sure to run Windows Updates and reboot the device. Then try again.
When that still fails, please list the exact URL of the version downloaded as an answer.
It probably concerns release 20.0.151? We have found that Data Hub release 20.0.151 there is a conflicting configuration in the installer causing the installation to prematurely end without upgrade/installing the product. Thanks to @anon34686425 for reporting it.
This problem as far as known only exists for the combination of version 20.0.151 and Invantive Data Hub for Windows.
In case the issue occurred on 20.0.151: please use version 20.0.152.
